What oil brand do you use on your Fiesta ST?
  • Motorcraft
    Votes: 119 27.0%
  • Havoline
    Votes: 0 0.0%
  • Quaker State
    Votes: 4 0.9%
  • Castro
    Votes: 55 12.5%
  • Valvoline
    Votes: 18 4.1%
  • Pennzoil
    Votes: 71 16.1%
  • Mobil
    Votes: 122 27.7%
  • Pure Gaurd
    Votes: 0 0.0%
  • Lucas
    Votes: 1 0.2%
  • Redline
    Votes: 16 3.6%
  • Other
    Votes: 63 14.3%
  • Total voters
    440
Capri to ST
Looks like I'm going to be switching from Royal Purple to Pennzoil Ultra Platinum Pure Plus.... There is a ton of information in this link, it took me about an hour to skim through it.
https://540ratblog.wordpress.com/
that does have a lot of well-documented info- has anyone got an opinion about the Quaker State Ultimate Durabilty full synthetic that was very highly rated (3rd out of over 150 oils tested) on there? I hadn't seen anyone mention it on the intake valve carbon buildup thread,and had not thought of QS as one of the better oils
EDIT- I clicked on the poll results, only 1 out of 224 people using it
JTP
I think going with the regular Pennzoil Platinum PP is the better choice due to less additives for the valve build up. If I wasn't taking my ST on the track or anything that is what I would use.
I made that swap at 20k. Went from Mobil 1 to the Pennzoil.
I went on the hunt last night for the Pennzoil Ultra Platinum Pure Plus(mouthful)...Walmart, autozone, or discount auto parts doesn't carry it. They only have the regular platinum. I'm going to check out Pep Boys tonight which shows that they have it at my local one by the quart only.
I found the Ultra at Pep Boys so I went with that. I changed the oil over the weekend. So far so good.
I use Schaeffer's oil. I have always had great luck with their oil.
OffTheWall503
Yep, I am using it in mine. Will do a UOA when I do my first change.
Just make sure it meets Fomoco spec and you will be just fine....
MotorCraft for first change, then most likely Mobil 1 from then on.
Anyone try Joe Gibbs racing oils? 5w-20
Designed for high performance Ford modular engines. Utilizes advanced synthetic base oils to provide high temperature and high shear protection.
I used this brand with my Shelby.
Ford motorcraft spec is API SN. Any API SN rated oil is great. Buy what's on sale and enjoy your car.
Rhinopolis
GASP, blasphemy...lol. Engine oil is serious business and needs to be debated and reviewed under a magnifying glass for all of time the end.
I started using Driven Oil at the request of the builder who did a pushrod 5.0 engine for me. No issues as yet.
I emailed Driven about oil for the FIST and was advised to use LS30. Its been in the car just over 3k miles now.
I am curious to find out if I have more or less residues in my Damond catch can since I have switched from Motorcraft synthetic blend to the Driven Oil.
