VT330R Hybrid Turbo Kit Install and Review
VirtualRonin
VirtualRonin
Active Military
Ajo, AZ
Thread Starter #41
I see you had to trim the top half of your heat shield. I can see how their elbow not work with the larger cpe hot side pipe, but what’s exactly the issue with their elbow not working with the Ramair crossover pipe?
The elbow had to be trimmed so it wasn't so offset from the turbo but that was no problem. The problem is that it's a 5" long elbow and vertically it just barely mates up to the crossover but with no overlap to install a clamp.
koozy
Los Angeles, CA, USA
#42
Ah... okay, I think Vibrant has an 8” leg elbow available, 3” to 2.75” which I’m guessing is what your turbo inlet looks like if you can’t find something to work locally. Its what I used for my GTX 3” inlet to mate up to the 2.75” Ramair pipe.
VirtualRonin
VirtualRonin
Active Military
Ajo, AZ
Thread Starter #43
Ah... okay, I think Vibrant has a 8” leg elbow, 3” dia. to 2.75” which I’m guessing is what inlet looks like if you can’t find something to work locally. Its what I used for my GTX 3” inlet to mate up to the Ramair pipe.
Thanks! I'll look that up and order one I think. I also just ordered some silicone couplers and aluminum joiners on Amazon Prime so I'll have them Monday. That should get me up and running again once the TS Plumb Back comes in Monday or Tuesday.
VirtualRonin
VirtualRonin
Active Military
Ajo, AZ
Thread Starter #44
My Amazon order came in today. I ordered a 2.75" aluminum joiner and 2.75" silicone coupler for the crossover pipe and a 1.5" aluminum joiner and 1.5" silicone elbow for the hot side charge pipe. I also ordered a 1.75" to 2.5", 45 degree silicone elbow to replace the the 1.5" stuff but it won't be here for a few days.
Here are the elbows from the kit. They did not come with any clamps.
And my Amazon ordered parts
Elbow for the crossover pipe to turbo
Intake installed
Elbow for the hot side pipe
The Turbosmart Plumb Back should arrive tomorrow. With any luck I'll have it on the road for a test drive tomorrow evening!
#45
This should've been a plug and play just like a Garrett...everything should be included and no dinging around for the buyer.
felopr
JD
#46
Turbo and manifold are mated up and almost ready for install. Ran into a small issue though. My Turbosmart Kompact Dual Port is about 10mm longer than the Plumb Back version which is making it difficult to install the turbo intake elbow. So, the best option is to use a Turbosmart Plumb Back or use a block off plate and relocate the BOV. I have one other option I'm looking into. The stock BPV absolutely will not fit either.
By the looks of it, the new turbosmart EM bov wil fit barely
felopr
JD
#47
I was thinking the same thing but i am gonna reserve my comment, he is using a cpe prototype manifold, we don't really know if it moves or doesn't move the turbo from "stock" location, unless someone can confirm...
ron@whoosh
Vendor
Las Vegas
#48
guys, relax
Nick from AET asked me what to send with the kits
Just like the ATP 2860R kits the hot side pipe connects to the "oem pipe" every ATP kit I sell results in someone asking why it doesn't work with their Mishimoto, COBB, or cp-e hot side charge pipes
As for the connection for the turbo inlet to crossover, this is something that will have to be corrected
VirtualRonin
VirtualRonin
Active Military
Ajo, AZ
Thread Starter #49
guys, relax
I actually emailed Nick at AET this morning and CC'ed Ron. I just wanted to share my install experience with him so we can work to improve the kit. Since I'm one of the first to implement it on a USDM FiST I accepted the fact that it may need further development. Thankfully, the issues were definitely workable and correctable. Nick got back to me right away and seems very receptive and willing to work with Ron on updates moving forward.
VirtualRonin
VirtualRonin
Active Military
Ajo, AZ
Thread Starter #50
Turbosmart Plumb Back arrived this morning and is now installed. Still a tight fit with the silicone inlet elbow but it's acceptable. There's still plenty of area under the clamp to make a good seal.
The 45 degree step up elbow (1.75" to 2.5") arrived this morning as well and after some trimming, the charge pipe fits great!
Next I'll be flashing the new base tune from Tune+, firing it up, checking for leaks, then going for a test drive!
VirtualRonin
VirtualRonin
Active Military
Ajo, AZ
Thread Starter #51
So far so good, no leaks or issues to report. First 2 datalogs are done and have been sent to Tune+ for review. Next steps will be to work through the revisions and move on to E30!
Ottawa
#53
Very nice. Loving the write up so far. Interested in the performance and general feel. Are you running an LSD?
Looks like doing a BOV relocate is the best option. Too bad the cold side kits are so expensive (and I have the CP-E :p ).
VirtualRonin
VirtualRonin
Active Military
Ajo, AZ
Thread Starter #54
Yeah, I have an M-Factory LSD. I can't speak to performance and feel too much just yet; it's still very early in the tuning process and I'm currently on the initial custom tune. Wait a week or two when 91 octane tuning is done and I can give better feedback.
I would really like to do a CP-E and Tial or HKS BOV with a block off plate, and it did cross my mind, but I didn't want to buy more stuff than I needed right now. The Plumb Back is so quiet compared to the Dual Port but it actually feels smoother between shifts as far as turbo spool is concerned when getting back on the gas. Plus it's way more stealthy so I kinda like that too!
VirtualRonin
VirtualRonin
Active Military
Ajo, AZ
Thread Starter #55
Still working the base tune this week. As it turns out the IWG actuator that came with the turbo is only yielding 10psi of boost (ranging from 10.4-10.8psi though the RPM range). Adam was expecting 13-14psi with an 11psi spring combined with a 3mm preload. This was because I reported having an 11psi IWG actuator to Adam before getting my base tune. When he noticed it was low he asked me to check the IWG preload.
I checked the preload yesterday and it was exactly 3mm, so knowing that one can reason the actuator has a 7-8psi spring installed. Adam recommended we go with a higher base pressure so we have flatter boost in the upper RPM range. I do have the Tune+ actuator from my stock turbo so I am going to try to install that this evening. The dimensions look very close so I'm hopeful it will go in without much trouble. If it doesn't work out for some reason then we will continue tuning with the current IWG actuator.
#56
Can't you just take the spring out of one and put it into the other or is it a sealed unit?
VirtualRonin
VirtualRonin
Active Military
Ajo, AZ
Thread Starter #57
I would think so but it's much easier to swap them out IMO. If it comes to changing out the spring, then I may consider doing that. It looks like it would require a special spanner wrench at least.
#58
Then you have to ding with getting the wastegate preload setup right!
VirtualRonin
VirtualRonin
Active Military
Ajo, AZ
Thread Starter #59
To be fair, I don't have to change the actuator but to get the most out of the turbo, I should.
The preload was correct, but we thought the actuator had an 11psi spring instead of the 7-8psi spring.
#60
If it was me...I'd see if I can change out just the spring and not have to deal with wastgate preload garbage with the shaft and nuts....yes i said shaft and nuts in the same sentence twice now.
