Best Stock Quarter Mile Time?
Srienzo12
What is everyone's best quarter mile time on their stock Fiesta ST? Mine is 14.86 Sec @94.05 mph
Srienzo12
Srienzo12
Thank you! And that's the best ive seen too.
Truth in Ruin
It can be beat. If the car, and track is prepped well- you should be able squeeze out a 14.6
If I was trying I’d use about 22-24 psi in the front tires (assuming they’re Bridgestone), and about 40 psi in the rear tires. Remove spare, all trunk junk, passenger and rear seats. 1/4 tank of fuel w/ 25% ethanol mix. Remove air filter.
That oughta do it; if not, I’d give up lol
Do they prep the launch pad at Epping??
It would be difficult to get that 60' down too much lower on the factory Potenzas, with all of the weight transferring off of them.
Srienzo12
Srienzo12
They do prep at epping. And yeah the factory potenzas dont hookup well. But I was running them at the stock 39 psi.
My personal best is 15.1 at 95mph. That was completely stock and with a 180lb passenger. I reduced the stock front tire pressure to 30psi and pumped up the rears to 40psi but still got lots of wheel spin in 1st and 2nd. I think my 60ft time was 2.3 or 2.4 seconds, which is terrible.
Interesting how you got a 14.8 but only 94mph trap speed.
I want to go back and give it another go soon. I just put on a set of Falken Azenis RT-615K+ tires and they are a lot harder to break loose under hard acceleration. Hoping that increases the 60ft time. I also removed the spare tire and jack. Would that still be considered stock? I have zero mods done.
danbfree
Since you have a '14, they have pretty poor rear motor mounts while the '16+ got better ones, that's why you see those guys hooking up better for a lower time at the same trap speed... well, one factor anyway... And yes, removing spare and jack is definitely still considered stock, hell, I just keep a can of Fix A Flat in my car instead even for my daily! :)
alexrex20
I'm not stock at all but trapped 94mph on 6 passes last night. That's equal or slower than stock FiSTs. I'm stage 2 E30. I'm guessing the roof rack ain't helping. Here's my best time slip. The other 5 were 14.4/94 with a 2.2 60ft. At least it's consistent. Slow, but consistent lol
Ahh misread your city as spring branch.
Hmm I think humidity and temp may have played a role
alexrex20
It was quite cool compared to recently. 90F and probably 100% humidity haha
