Installed 12 out of 16 ARP wheel studs. Also color questions.
If you drive hard, the center caps just disintegrate. I have team dynamic wheels, I no longer have center caps
D
DAPR
Finished the stud install. Looks great! Also replaced at the stupid factory lug nuts
Well that's a no brainer. [histerical]
Unless you cut the studs or open the ends of the OE nuts they won't fit.
However you are correct, the factory lug nuts are stupid. [screwy]
I like it.
Dave
Are those 17mm hex open ended lug nuts, and if so WHERE did you find them?!
D
DAPR
I like it.
Dave
They fit just fine!
D
DAPR
19mm they were super cheap, just using them to hold me over.
Do you use a thin walled 19mm socket in order to not scrape the sides of the lug inset/'pocket' of the 1.2s??
I have a deformed stud, do you need to pull the hub off, or can you get enough clearance just removing the caliper and disk?
