Installed 12 out of 16 ARP wheel studs. Also color questions.
Ridgecrest
If you drive hard, the center caps just disintegrate. I have team dynamic wheels, I no longer have center caps
D
DAPR
Charlottesville
Finished the stud install. Looks great! Also replaced at the stupid factory lug nuts
U.S. Navy Veteran
SFV, So.Cal.
Well that's a no brainer. [histerical]
Unless you cut the studs or open the ends of the OE nuts they won't fit.
However you are correct, the factory lug nuts are stupid. [screwy]
I like it.
Dave
D
DAPR
Charlottesville
I like it.
Dave
They fit just fine!
Anchorage
I have a deformed stud, do you need to pull the hub off, or can you get enough clearance just removing the caliper and disk?
