- Member ID
- #9137
- Messages
- 504
- Likes
- 115
hey everybody this is for the heads who got their recall done at the dealership. i am referring to the coolant temp sensor and new reservoir that was changed out i will provide a pic later. I wanted to ask how they did your recall if you can please look at the new metal tube that comes out of your coolant bottle and runs along the front of the car next to the ac line. my question is do you have a bracket holding up the line or is it secured in any form or fashion. just very curious to see how other dealers did the recall as i have had issues with the dealer i went to .
basically how they did mine is they did not put any brackets or supports so the coolant line rests on top of the ac line bracket and at another bracket down the line. basically i have 0 support to hold up the new coolant line and it is rubbing against the ac line. It will eventually rub a hole through as you can already see that the 2 metal lines are rubbing against each other and you can see the wear it is causing on both lines. so i am trying to see if they did your cars differently or is this the norm?
i personally think 2 metal tubes of opposite temps touching and rubbing is not a very professional way of fixing somebody's car.![Bash [bash] [bash]](/images/smilies/icon_smile_bash.gif)
