Need brake fluid help.
SLIDELL
This is what my brake fluid reservoir looks like atm. Ford said they topped it off when I got my tires rotated but it doesn't look like they did. Car has 28k miles on it. Not sure why it's so low. I'm assuming I need to fill it. What brake fluid should I buy and do i just pour it in that opening? Thank you.
Pleasant Garden
All right follow that tube and you'll actually see the larger reservoir that has your level line on it. Brake fluid goes down as your brake pads wear. It's never recommended to add brake fluid because when you change the pads and you push the caliper back all that fluid in the caliper goes back up in your reservoir. If that reservoir is full or close to it due to topping off the brake fluid it would spew out the top and make a mess everywhere.
RubenZZZ
Montclair CA
FWIW, I needed to swap pads right around 25k.
Your rears probably need replacement soon.
Sent from my 2PYB2 using Tapatalk
Boston
I can confirm this information, mine looks like yours right now and has for the past few weeks and my pads are very low. At 28k miles your pads are probably due. I got 25k out of my last set of OEM pads
Id be less concerned about the fluid level of the vehicle and more about keeping your windshield cowl for the wipers from acorns and leaves due to the sediment buildup overtime. But that's just me.....[party]
J
SLIDELL
Okay, that's interesting. Does the brake wear have anything to do with the torque vectoring system?
J
SLIDELL
Lol, it's due for a cleaning
