Fiesta Cat Back w/Inceased Performance while remaining Quiet?
Well, on a positive note, I've already got a true 3" DP I wasn't using, so I suppose the Thermal R&D exhaust would put that to use. I just wish it was closer to stock sounding. It's nice being able to flog the car a little without drawing any unwanted attention. You never know who's listening and judging. The Thermal R&D may not have any drone but it still seems to be much louder than stock based on the youtube vids.
Its not loud enough to draw any attention from Cops. Oh and ya I have it on a Orange Spice car and they do not even look at the car anyways lol.
Clint Beastwood
I'm not sure but I think the thermal comes set up to connect to the stock DP. If you're stock DP you should just stick with that + the thermal and sell the DP to recoup some money, making the thermal cheaper. You are gaining literally nothing except some extra noise using a 3" dp on a stock turbo'd FiST. If you want it to sound closer to stock, use the stock DP. The bigger DP is going to make it even louder and raspier.
jeffreylyon
Exactly why I'm looking for low/no volume increase.
Then the stock exhaust is exactly what you want - low/no volume increase and the same performance (with a stock turbo) as any of the aftermarket exhausts.
Mikey456
Kind of a separate question... but if you commit to one cat back exhaust or another, isn’t it possible to have a muffler shop weld it in instead of having to tightened the clamps periodically, as the OP said?
Of course, but I wouldn't do it. Once its welded in you're stuck and you'll need a saws-all to remove it. It's not a big deal crawling under the car every once in a while. I can't go a month without getting under mine tracking down squeaks, changing a turbo, inspecting vacuum lines, etc.
Clint Beastwood
Another option (expensive) is to have it v-banded. Since I swap exhaust systems so often and frequently go back to stock, I had mine v-banded where you would normally cut it to remove it. On a lift it takes 10-12 minutes to go back to stock. I have an MBRP on there right now while I do my nerd stuff figuring out the math for cancelling the drone and those (mbrp) clamps lick the big ones - I've had to realign the tips 3 times in like 8 days. I *think* I'll wind up cutting off the MBRP "Y" and just putting a dual tip on the back after it comes to rest where it wants to.
