Spice under the Knife. ( Now S280 powered!)Dpro’s 2018 Orange Spice STGOKRT official Build! Part two the rebuild coming!
The Pro Alloy stuff is sick. There intercooler and crashbar are awesome. If you are going aftermarket crashbar in my opinion there is no better. I am not sure you can buy it without their intercooler.
There radiators are really nice as well.
I am happy with the Mountune though. My temps are down a good 10 degrees. Thats cool you can go see Jason in person. I am probably going to get some of his tunes on the next sale.
Yeah, according to Ron, both the Pro Alloy and the Mountune do actually have a smaller coolant capacity than the Mishi, but that is NOT the sole/only factor in maintained low coolant temps by a given radiator. [wink]
Thread Starter #42
You are correct flow design really can make a difference the Mountune I believe is a triple pass cross flow. Thats an optimized flow pattern. I am sure its the same deal with the Pro Alloy.
Thread Starter #43
Oh look what we have here a new Whoosh Motorsports Aluminum cold F7E587C4-6973-4B60-814C-6C6BD882E119.jpeg side charge pipe in Crinkle Black . Per D-Resonants findings actually helps in keeping your charge temps cooler
Going in shortly provided I start early enough in the day to install with the fricken heat. Lol
koozy
Los Angeles, CA, USA
#44
Oh look what we have here a new Whoosh Motorsports Aluminum cold View attachment 22908 side charge pipe in Crinkle Black . Per D-Resonants findings actually helps in keeping your charge temps cooler
Lets see it. [emoji1787][emoji2935]
Thread Starter #46
Its been a minute life moving and whatnot. Anyways Camber plates in this week will have pics Also New shoes! 16x8 Konig Dekagrams with Federal RS Pro’s 205/45 16 ya they run wide so very little stretch that stiffened up the sidewall. Rides great Turn in is good pretty damn stickly. 54C3A79A-AD35-4DE7-9B08-A39B21BBC196.jpeg E4FB1331-DD9D-4D0C-A51E-9C2BCAA529D4.jpeg 43179C0E-7855-4D13-AF54-78B341480B66.jpeg 216A8F94-E1A8-4B17-885C-10ADC1FE17BB.jpeg 10784A98-D97E-4D6B-8ABC-916FE7484326.jpeg
Montrose
#48
Dave
Its been a minute life moving and whatnot. Anyways Camber plates in this week will have pics Also New shoes! 16x8 Konig Dekagrams with Federal RS Pro’s 205/45 16 ya they run wide so very little stretch that stiffened up the sidewall. Rides great Turn in is good pretty damn stickly. View attachment 26204 View attachment 26205 View attachment 26206 View attachment 26207 View attachment 26208
Dave, have you used the Federal 595 SS or just the 595 RS? I’m looking at the Federal too cause ST needs new tires.
Thread Starter #49
Dave
Hi Bryan , Ya I would say do not get the 595 SS they are old and did not have a good rep. I did use the 595 EVO on my P10 Infiniti G20 and it was not bad. These tires are miles away better than those though. Stiffer sidewalls,stickier, lol
I almost bought the RSR’s which are supposed to be pretty good too. I just decided to spend more and try out the RS Pro.
Montrose
#50
Awesome I’m glad I asked! Thanks you!
Thread Starter #51
So did a little thing this week, yup installed rear camber plates 1.8 degrees negative Camber! Did a test run on part of Angeles Crest today and combined with the RS Pro’s the car now has a whole new much higher level of breakaway. I am going to say its way up there. E1F769B2-0CC0-438D-8177-52BDF82C7539.jpeg 876678AA-17C1-48DA-A797-B27ADF11EA73.jpeg 7526B650-3B0A-4A61-A3A5-68E94B31DFAF.jpeg ADB88F8C-E60B-43ED-B592-63253A015B27.jpeg 81BCF318-3928-43FD-8D7F-9A747B82EFBD.jpeg D1EC6372-1E46-4521-9B6E-26245F77A4C6.jpeg BD4AD2DC-B48B-4E75-ACD7-DFC715528BDC.jpeg
Thread Starter #57
So have not posted in a minute . Ya some new things have happened A84157A1-BB20-4EF4-8F15-1C258F2849B4.jpeg but I do not have install pics A4F191C2-701C-48C7-BE97-890B258A674B.jpeg 92631B09-9D51-44AE-B65E-97C23C5DB7BD.jpeg 113168F1-B949-408E-8513-A51F58E2229C.jpeg pics.
She is now running a Turbo Technics S280 Turbo with a Mountune Sport cat and a Vibra Technics RMM Fast road.
Thread Starter #59
I should add the S280 is an awesome Turbo. Picked the car up from the Tuner on Sat and it was causing clutch slippage above 25lbs of boost in higher gears on the dyno.
Its now just silly fun and completely ticket worthy.
Brakes up next EBC Yellows with EBC rotors being shipped as we speak.
