Idle AFR Swinging Rich to Lean
gtx3076
I took a log to send to Dizzy but my AFRs sometimes swing from the 13's to the 15's while idling, A/C off. I'm tuned in E30 and am running step colder spark plugs. AFRs make me think maybe an 02 sensor. Car has 100k miles and is 5 years old.
It's not all the time, just intermittently, other times AFR's stay in the 14's at idle like I'd expect. Anybody else experience something like this?
Se7eN
All the time, even from new. Mostly after filling up with gas, or if it's been on for a while. Doesn't affect anything.
Same here, happens every now and then. Ac cycling on an off puts a load on the engine that could be doing it even pressing the clutch in and out. Doesn't hurt anything.
bad evap purge valve, I changed mine and it went away.
It will probably come back when this one fails.
Buy the one that comes with the hoses.
G
gtx3076
Is that why I smell gasoline in the car after I fill up?
