- Member ID
- #11107
- Messages
- 39
- Likes
- 21
Ok so i was working on installing an AWR RMM.
the two main bolts were stuck but easy enough to get loose with some wd-40.
now my problem is the the stud that holds the bracket, park number W716047-s442
now i can order a new one, even tho i wouldn't want too, the "overnight" shipping would still take 5 days, and cost at the lowest 40 bucks for a 12$ bolt
Now i stopped myself from get two carried away and let it soak in fluid for the night and put the rest back together.
im looking for ideas on how to extract this stud without causing two much damage
(to put it into perspective i was using a cheater bat on my 1/2 inch ratchet and honestly think it broke some ratchet teeth)
i could buy a slightly smaller breaker bar because mine doesn't fit under my car while only on jack stands
my main problem is the bolt is now slightly rounded off and sockets just started to slip off.
this stud just seems to be really seized and cant find a way to get at it.
any and all recommendations would be helpful
