Just finished my HS set up
A
Thread Starter #24
How are the konis working out for you?
I think fine, I still need to learn how to set them, like fine tuning, as of now I have a slight conflict because of two different tire pressures set ups, higher on the front vs higher in the rear... what is your opinion looking at my set up?
Thanks
Andres
Plainrt
Lol you have more experience than me. I didn’t like the rear bar with those konis but you have a nicer bar setup. When I got the rear of car neutral feeling I only slightly adjusted the fronts here and there. I always ran few lbs more in rear.
Just imagine how much more complicated they would be to fine tune IF Koni had offered us the double adjustable yellows, (like I had on my Z28 way back when they were available), and you had to worry about setting the compression as well. [wink]
