SLD Gold Coast Big Brake Kits (323mm Front & 302mm Rear) Monterey, CA *PRICE DROP
Trader history for Fiestig (14)
Fiestig
Fiestig
Thread Starter #41
Bumpity, bump bump
jayrod1980
#42
I have the front and rear set up and it’s awesome... improves stopping power and “looks nice” having the 17s filled in over the stockers. I did however hit the inner area the pads don’t touch with high temp black paint so I don’t have a big rust ring where it doesn’t touch the inner area of the rotor from the caliper.
I needed to change my pads at minimum anyway and it was an easier job than a front BBK system. Just don’t be a moron like me and make sure you crack the bleeders before compressing the stock pistons or you will need to get out your laptop and Forscan and do an ABS system bleed. The brakes will drag if fluid gets pushed up into the abs system.
Fiestig
Fiestig
Thread Starter #43
bump bump
Fiestig
Fiestig
Thread Starter #45
Yeppers
Fiestig
Fiestig
Thread Starter #46
Bumpers
Fiestig
Fiestig
Thread Starter #47
#BUMP and Price Drop Tired of these sitting around not getting used
323mm Front Kit: $440 $350 $300 PLUS $20 USPS Priority Shipping
302mm Rear: $300 $240 $200 PLUS $15 USPS Priority Shipping
pixelzombie
#48
I was under the impression you just need to loosen the cap to the brake fluid reservoir before compressing the pistons.
Fiestig
Fiestig
Thread Starter #49
I have only ever taken the cap off. I have had 0 issues in doing so. But to each their own.
jayrod1980
#50
I would still personally do the forscan abs bleed, but I’d imagine if you crack the bleeders you won’t have fluid pushing back up the line like I did. Regardless, this is a great upgrade. Zero fade, looks great under 17 inch wheels, and noticeably stronger performance.
Fiestig
Fiestig
Thread Starter #51
bump
Fiestig
Fiestig
Thread Starter #52
Bumpity
#53
I will buy the fronts if they will fit under 16 inch rota grids, but I don't think they will.
Fiestig
Fiestig
Thread Starter #54
I don't think that they will either. I am putting on front sway bar poly bushings this week. I can throw the kit on just to see with my slipstreams. Pretty sure rota uses the same wheel dish.
