My wrench light is on all the time with no code signals on my Acessport. Car runs great no clutch issue, slight noise when cold ,running in neutral with clutch out. Clutch take up and acceleration is fine with no slippage. Running Cobb 91octane stock car
The wrench light can just mean that you're due for an oil change, it can be a maintenance reminder. The last time mine was on that's all it meant, they changed the oil and reset it, and one year later it was back on again.
On my 2014 ST, my wrench light came on, and the break/accelerator reset didn't turn it off. However, after I added coolant to the fill level the light turned off.
My wrench light is on all the time with no code signals on my Acessport. Car runs great no clutch issue, slight noise when cold ,running in neutral with clutch out with Cordless Impact Wrench. Clutch take up and acceleration is fine with no slippage. Running Cobb 91octane stock car
The wrench light is most likely just a maintenance reminder, not a fault code. If the car runs fine with no clutch slip, you can reset the reminder and keep driving. The slight cold noise in neutral is normal gearbox or throw-out bearing chatter.
