Loss of Power / no power, "chugging" a little above idle
C
Plano, TX, USA
Thread Starter #21
Unfortunately on compression check, cylinder 4 pulled the spark plug out with split and burned up coil, meaning spark plug was stripped off and then eventually blew out*. I may need to put on a (1) new head unless I can get a (2) thread repair to work. This should fix the issue and I will keep thread updated. Although the behavior prior to blow out was peculiar the engine codes and final behavior matches symptoms.
Another thing to note, I had taken the car to a ford dealer and they told me the clutch needs to be replaced to fix it -- this was not the problem.
*I am always extremely careful not to strip threads but apparently this time luck was not on my side
Thanks for all the comments
Who did the last set of plugs?
Rocketst
Chesapeake, VA, USA
Don't feel bad man. I have a brand new motor that mountune built and I have at least a dozen helicoils in the thing already. The aluminum ford uses isn't exactly the cleanest quality and it shows with some of the hole threads. They don't seem to hold much torque cuz I've even torqued some things to spec only to have them pull the threads out. Just helicoil it if you can. You'll need to take off the head to make sure you don't have any metal shards left over after drilling out the studs so prepare to replace a head gasket.
Sent from my IN2019 using Tapatalk
They make Helicoil kits so you don't have to removed the complete head from the vehicle BTW. You just have to find one with the correct insert. There are those who have done this on other vehicles and used wheel bearing grease on the Tap to help catch and shavings by removing it periodically and changing the grease on the tap* Good luck
C
Plano, TX, USA
Thread Starter #26
Did someone run the plug in with an impact?
No impact, but I didn't use a torque wrench. I don't really remember much about changing the plugs as it was a while back and I had no problems immediately after. Per some research, I was thinking of using the thread repair kit that have a punch for the shoulder of the thread sleeve. I haven't decided how much I want to pull off to do the job, i.e. telescoping in the space with the tools while using the grease method and then blowing out debris
The main concern is if it doesn't work -- that would require new head
PunkST
Menasha
Can you find a 1.6 turbo from an escape in your local yard. Its quite literally the same engine. And that you have a whole spare to work with.
You may also find it in some fusions.
C
Plano, TX, USA
Thread Starter #28
I wish I had a shop and I would definitely work on engine(s) more, its just not in the cards for where I live right now with a small garage space. As for the tools, I ordered the Lisle 65200 kit and waiting for it to be delivered. I ordered this kit because it has a 3/8 in drive. On additional research, I found an oversized kit from Big-Sert which I suppose gives folks a second chance, as well as a machine shop may be able to give 3rd chance (possible).
...waiting for the delivery
Boston
@chrisj , how long ago was it that you installed your spark plugs? I'm having some anxiety now about my spark plug install I did without a torque wrench back in March 😬
PunkST
Menasha
#35
My two cents are never do plugs when the head is even warm. I havent ever used anti sieze or grease on any spark plugs ive done. Always went with hand tight first then use a normal ratchet for 1/ 16 to 1/8 turn on tapered seat plugs, and quarter turn on the ones with washers. Then again i dont have massive upper arm strength.
C
Plano, TX, USA
Thread Starter #37
I put in plugs about a year ago, no problems until about 9 months ago, so there was a period of time that had no issues/symptoms.
C
Plano, TX, USA
Thread Starter #38
I am still awaiting delivery for industrial cotton swabs and then I am ready to go on spark plug insert and then a compression check; I really hope this fixes everything. I also appreciate all the great input on this effort.
#39
How did this turn out?
