Ah no my RS Pro’s will out perform 615’s lol . In Fact RSR‘s will out perform 615’s. You are comparing Apples to Oranges the ST1 is not in the same class as the the 615’ . The 615 was Falkens old Ultra High Performance tire. While its still available the 660 actually is the replacement and its a much stickier tire than the 615.
Lets get this right here people you cannot compare lower line all season or product lines high performance tires to Ultra High Performance tires. The Falken RT615k was formerly Falkens Ultra High Performance tire.
I should also high and this had been said on this forum before you need to stop reading numbers on the tire sidewall. You should start looking and contact patch widths and tread widths to get a better idea of how wide the tire is on your rim.
Though are set numbers on the side that companies all agree to put on when it comes to manufacturing some companies run narrow some run wide. For instance Bridgestone’s tend to run narrow. So the contact patch and tread width is not going to be as wide as say any of the Federals. In fact Federals run so wide that a 205 is pretty much a 215. Hell my friends 245’s look like 275’s on his 240sx.
This is not so much a prop for Feddy‘s as it a reality check for a lot of the posters in this thread start reading tread width , contact patch, etc... of tires you are looking at . You can find them they are out there. I know I did and its why I put 206/45 Feddys on my Dekagrams.
On and just so you know Falkens run a little wide too not as wide as Feddys but wider than Bridgestone‘s.
Friend put RT615K‘s on his dekagrams in 215/45 and had switch from lowering springs to coil overs due to rubbing aka had to readjust height.
Its why you always look at the details rather than just reading sidewall numbers.
Also, I said the 615s are a bit better performers than the ST-1s (200tw vs 300tw).
The 660s, in my opinion, are not all that practical compared to the 615s. By all accounts they wear a lot quicker than the 615s and make a worse daily.
				![Wink    [wink] [wink]](/images/smilies/wink.gif)
