Is a catch can needed?
I’m about to upgrade to a X47r turbo and I’m curious if a catch can is needed or a good idea when pushing a lot more boost then stock.
Are you going to run Aux. Fuel of any nature? If not....then absolutely *
Its another boost leak point also I might add*
D
I’m not sure, I might go with updated injectors and a hpfp shim which would max out the X47r. But if I ever go to a bigger turbski and a built motor then definitely gonna go with aux fueling as well.
jeff
Where did you get that X47r badge?
Ordered letters on eBay and painted them. Just search "auto emblem letter" and pic what you want. It's X47 btw not R.
jmrtsus
I don't understand how the boost pressure gets into the PCV lines. Help a dummy please!
jeffreylyon
Piston ring blow-by. The rings don't seal 100% and leak into the engine case during the squeeze and bang cycles.
Capri to ST
I would highly recommend reading this link to a really informative article that Jabbit has posted in this thread, it gives a good explanation for how the oil separation system works. It also confirmed for me that I do not feel the need for a catch can, since the OEM system seems to do a good job, and since the catch can can introduce some problems of its own.
I've got the Damon OCC and haven't had any issues out of it at all , I empty it with what it catches with every oil change . Just have to make sure to close the valve nice and snug.
Ditto here on the Damon- stock boost I didn't feel it was necessary then a couple years ago when I turned up the boost with mods, I'm glad I have it. Each oil change I empty it and see what would have been recycled in my system. More in the winter with lousy gas.
Jabbit
Nobody has said how much is being drained out of the Damond OCC. Would like to know mods, interval, and capacity.
I change oil every 5k miles (motorcraft synthetic). I'm running full bolt ons with custom tuning with the stock turbo. I typically catch between 1-2 tablespoons of sludgy stuff. Winter time (New England) it has gone up to a shot glass or so with the poor gas.
Just went out, emptied and measured mine to see: about 1500 mi and 2 auto-x events I got 1oz of oil out of mine
edit: I've got radium, and it's Crank Case side only
jmrtsus
Every oil change 3300 miles avg. I get about 2 Tablespoons of oil out. Do they work? Of course they do! MP215 and Damond OCC only mods. No racing or autox, just spirited driving. Keep in mind that is over what your OEM separator traps. Ford put one in so they think our engine needs one, I say we need two if I am still catching oil.
