Is a catch can needed?
Stanwood, WA, USA
I’m about to upgrade to a X47r turbo and I’m curious if a catch can is needed or a good idea when pushing a lot more boost then stock.
Are you going to run Aux. Fuel of any nature? If not....then absolutely *
Its another boost leak point also I might add*
D
Stanwood, WA, USA
I’m not sure, I might go with updated injectors and a hpfp shim which would max out the X47r. But if I ever go to a bigger turbski and a built motor then definitely gonna go with aux fueling as well.
Capri to ST
CHAPEL HILL, NC, USA
I would highly recommend reading this link to a really informative article that Jabbit has posted in this thread, it gives a good explanation for how the oil separation system works. It also confirmed for me that I do not feel the need for a catch can, since the OEM system seems to do a good job, and since the catch can can introduce some problems of its own.
Central CT
Ditto here on the Damon- stock boost I didn't feel it was necessary then a couple years ago when I turned up the boost with mods, I'm glad I have it. Each oil change I empty it and see what would have been recycled in my system. More in the winter with lousy gas.
Jabbit
New England
Nobody has said how much is being drained out of the Damond OCC. Would like to know mods, interval, and capacity.
Central CT
I change oil every 5k miles (motorcraft synthetic). I'm running full bolt ons with custom tuning with the stock turbo. I typically catch between 1-2 tablespoons of sludgy stuff. Winter time (New England) it has gone up to a shot glass or so with the poor gas.
Boston
Just went out, emptied and measured mine to see: about 1500 mi and 2 auto-x events I got 1oz of oil out of mine
edit: I've got radium, and it's Crank Case side only
jmrtsus
Ooltewah
Every oil change 3300 miles avg. I get about 2 Tablespoons of oil out. Do they work? Of course they do! MP215 and Damond OCC only mods. No racing or autox, just spirited driving. Keep in mind that is over what your OEM separator traps. Ford put one in so they think our engine needs one, I say we need two if I am still catching oil.
