A little extra E
Trader history for its_stock (0)
its_stock
U.S. Air Force Veteran
Tokyo, Japan
Has anyone experimented with adding a few extra percent Ethanol in the tank during fill up?
I am finding my car is much happier at E35 than E30. Especially on hot AF AZ days.
Erick_V
San Antonio
I have his ECG and I see less corrections when running between E35-E40, plus it saves me a little money lol. I believe most tuners factor in +\-10% Eth content. I usually shoot for around E35, I’m in Texas so the heat is a killer here too.
running a gallon of ethanol with a full tank on a regular tune will not hurt anything . It fact it will lead to less chances of knock . It’s especially good to do in areas of high heat.
gtx3076
US
I've done it, it's fine.
Just today I was in the area of the ONE E85 Wawa station within 50 miles of me, and I put about 2.25 gallons in a full tank of 93 E10 Sunoco, and it is fine even on a factory tune and snail.
Sadly, I guess because they know that they have the ONLY E85 in a 60 mile radius, the price has now gone up to $3.10 a gallon, almost twice what stations get for it in most mid western states, where it is plentiful, if not available at EVERY single pump. [mad]
gtx3076
US
E85 here in Texas is usually the cheapest fuel.
gtx3076
US
Paid $2.25 today for E. $3.10 is what I paid for 93 here in SATX lol
If I could run E85 and make like stock HP I would. According to Jason the fuel pumps can't keep up. I'm curious though since it seems to be safe to lean out E85 a lot more than gas.
Erick_V
San Antonio
Had the same thoughts, I get consistent enough E85 to make it work. We'd likely have to do HPFP and injectors at the minimum
Beegee
Kansas City, KS, USA
I misCalculated a couple weeks ago and ended up with 40% estimated. Didn't notice an real difference. Still hit max boost with proper advanced timing correction. Put in a gallon of 93 to level out after i burned through some. The mpg on E is definitely noticeable lol
