Pro Race Wheels For Your Fiesta ST !
Trader history for PCA-1 (0)
PCA-1
PCA-1
Thread Starter #542
So you think the 15x8 is the best fitment for our cars PCA?
I can make an argument for each size wheel. Everything depends on what you want, which boils down to appearance and use IMO.
GENERALLY SPEAKING:
Appearance is just that. You have to like what you see, be it wheel diameter, offset, and tire mix. Not speaking to color hear as color is subjective.
-Wheel diameter can singly be a personal visual choice. Like 18" wheels, buy 18" wheels. 18" wheels do not necessarily increase performance unless they are much lighter than stock with the tire & wheel package being lighter than stock as well. For a Fiesta ST, 18" are generally not a typical choice due to the wheels being so large/not very proportional to the car itself and the increase in ride harshness due to the necessary shorter sidewall. Lowering diameter, say going from a 17" wheel to a 15" wheel will soften up ride quality some and numb the steering a pinch. 15" tires typically cost less than 17" counterparts. A softer ride and less expensive tires are the main draws for street use. Smaller diameters also come into play as the closer the wheel rim is to the hub, the closer to the hub the wheel weight is, the easier it is to turn the wheel ("free horsepower"). For autocross guys, this is preferred as transitions in speed are affected, having more power at lower speeds.
-Offset positions the wheel either forward (outward) of the hub or backward (inward) from the hub. The absolute hardest thing in regards to offset is the ability to choose the offset best for your wants/needs. 99% of aftermarket wheels manufactured are available in one offset. You don't have a choice because wheel manufacturers want their wheels to fit the widest range of applications possible, which means offsets are typically an easy fit (safe offset/no rubbing). Favorable offsets range from stanced (offset so low the wheel rim pokes out past the fender requiring any one or combination of fender rolling, fender pulling, and camber adjustments), to flush (just enough offset to place the wheel rim at the fender line (still may require fender pulling, fender rolling, and/or camber adjustments, usually two of the three (fender roll and camber adjustment), to "safe" offsets (no rubbing) generally found in the wild that are generally -5mm from stock. So you will see a 45mm offset aftermarket wheel for a car that comes from the factory with a 50mm offset. 5MM lower than stock shows up visually as a wider track, anything less gradually backs into the wheel well, giving off more of a stock appearance.
-Tires :The #1 biggest mistake made by new wheel buyers is to try and fit the widest possible tire. The problem occurs as once you are wider than .79" from stock, the height of the tire starts showing up with dropped suspensions. Basically the wider you go, the taller you go. Making a mistake here costs money. That aside, tire choices are also dictated by the market. Today's 17"+ wheels are standard issue on the majority of new cars, thus there are more tire choices. 15" and 16" are almost non existent but for older cars that are still popular/in existence. So there is give an take. Go with a smaller diameter wheel, have fewer tire size choices.
I could go on here but have run out of time for now. There is more, say for example type of wheel manufacture, expected quality, finish reliability, etc. After reading this one may be more confused than before. Understandable. But really it is not too difficult once you are familiar with some basic things. I have not proofed this yet so pardon any grammar issues. Will try and get back to this as soon as possible.
Nice, hmm I def wanna under size from the stock wheels but still not positive on whether I wanna do 15 or 16in. Thanks for the help.
Capri to ST
I've had mine for a couple months now and love them. They're over 5 lb lighter per corner in stock 17 x 7, and the difference is quite noticeable. They also look great.
chi
Can't recommend the 15x8 TDs enough. They are fantastic on our cars!
Just ordered up some Bronze 15x8 TD's. It will be spring before they go on just grabbed them up while they were on sale. Pumped to see them on my Mag grey though. PC-Autosport is excellent to deal with, but everyone knows that already.
PCA-1
PCA-1
Thread Starter #547
Going to look great!!! Good plan taking advantage of the sale pricing. It is the best pricing we have all year!!!
PCA-1
PCA-1
Thread Starter #548
Sets are selling!!!
Plainrt
I believe he is still trying to work out things with new distributor. I'm sure will be back to normal business soon.
Do you have anything in stock in 15x8? I sent you a pm but never heard back. Trying to decide on color but if you have something in stock that could make the deal.
PCA-1
PCA-1
Thread Starter #555
Have Gloss Black, Matte Black, and High Power Silver.
Plainrt
Bump for team dynamics.........
I got my new 15x8s in matte black like a week ago. Wasnt wanting another set of black ones so painted them. Can't wait for it to get warm.
^^^These wheels look GREAT in ANY color! [thumb] (But that is sharp, and different. ;) )
