A/C causing overheating
Indio, CA, USA
So my car runs pretty damn good, the A/C blows cold and it has 59,000 miles. My issue is that where i live in California, its gets 120 degrees in the summer. My car will run at around 205-210°F and run normally, but once i turn the a/c on it will rise all the way up to 227°F and if i dont turn the compressor/A/C button off it will just keep climbing, its so annoying. My tune actually seems to help the situation out due to the fan speed being ramped up, but still not enough. Anyone have any ideas on how to fix this besides getting an expensive ass aftermarket radiator installed.
Central CT
Turn the tune off and remove the aftermarket intercooler or buy yourself a new radiator. It sucks, but those two things cause the stock radiator to underperform in high temps. I just went down this road.
Of course you could just run without AC for those days.
Are the Fans coming on when they A/C is on and your stopped and at operating Temp? I also second the Mountune or Mishimoto radiators. This will most likely solve the Overheating woes*
Burlington, NC, USA
Sad truth - none of the options are going to produce a good result and cost nothing. You can have a good result, or pay nothing. Only way to get good AC, low temps, most power is to upgrade radiator. FWIW, it's well worth the price if you can swing a few hundred bucks. Install is pretty easy. I had it done in ~6 hours and I'm slow af.
If upgrading radiator is out of the question (and you've verified the fan is working correctly), you could try running a higher % of water.
Mikey456
Los Angeles
Why would an aftermarket intercooler be a partial cause of overheating? Is it just the size that limits airflow to the radiator?
Blanco_ST
Indio, CA, USA
Yah the fan is basically on the whole time while driving up until i turn it off. all though i wish it would continue to spin even when the cars off just to keep cooling it down.
Damn I realize that im going to have to just purchase an aftermarket radiator.
Blanco_ST
Indio, CA, USA
Thank you for this information 🤙🤙
Blanco_ST
Indio, CA, USA
FWIW im having some trouble finding that brand? Maybe im reading this wrong
Albany
I had the same experience the other day for the first time. I was idling in freeway traffic 10 minutes, maybe 93-94 degrees out. I just have stage 2 ots tune and the depo intercooler, no upgraded radiator yet.
kivnul
U.S. Army Veteran
Deer Park, WA
Highly recommend Mountune radiator. I had some emails recently that made it look like they were having a sale, might be worth a look.
Easton
Some on here will claim that these have no/nada/ZERO effect at all on the coolant temps, even of the factory radiator, but I personally just don't see how they possibly could not. [wink]
If you think about it, it hurts in 2 ways.
1. It blocks a little more air flow to the radiator.
2. Being more efficient at heat transfer than stock IC, it has Hotter air coming through to the radiator!
(Still needs better radiator)
EXACTLY my thoughts as well, but others on here even with full radiator blockage size intercoolers vehemently deny this.
Not sure how this system is setup. I could look it up in the manual if desired. But my prior car had a two speed fan. Like most modern cars it rarely ran the fan unless the A/C compressor was activated. That only defaulted to low speed. I never even knew it had another speed until a few years down the road it kicked into high or what I like to refer to as, "wind tunnel" mode. In some vehicles, that seldom-used high speed fan relay would fail. So they'd be stuck with having one fan speed. The two fan speeds could be tested via diagnostic mode.
So my question is, have you verified that the fan is capable of achieving all its turning speed?
EDIT: Some will inevitably assume that I'm saying it's not the radiator. Didn't say that. Just something else to check while you're adding that new radiator.
While yes it could be that possibility though not likely on a newer car. OP is from Indio that is the Desert so I would hazard to say yes his fans are working fine and yes he needs to upgrade his radiator. I had the except thing happen to me here in Los Angeles. Oh and ya we were considered Desert once as well. :LOL: at people not considering LA a Desert.
Oh and that was with the stock intercooler on mine lol. I upgrade my intercooler and radiator at the same time. I have not had a problem with temps ever since even in 100 degree temps running the canyons on a bigger turbo a few weeks back I might add.
^^^The CP-E is NOT one of the intercoolers which blocks the front surface of the whole radiator though.
But yes, I do not want to install my CP-E until I have a Mountune radiator to install at the very same time. [wink]
@Dpro - I see my "EDIT:" message still didn't work. 😋
BTW, I did attempt to lookup the circuit diagram for the fan system earlier but the already ancient program from 2005 that Ford/Helm uses to show their diagrams has an apparent compatibility issue with Win10 21H1. 🙄
