Turbosmart spring questions?
Stanwood, WA, USA
Why would someone opt for a 7 psi,11,14 etc.? I have a 7psi spring in my turbosmart actuator on my PumaSpeed X47r. I am currently at 20psi on my current revision what or why is the benefit of a heavier spring?
Its holds the wastegate door shut longer*
Using a bigger spring isn't always the answer also*
But if you can hit 26psi with a 7 pound spring why would one use a heavier one?
It can aid in the bleeding off pressure by the wastegate allowing higher boost to be ran. And held for longer in the upper RPMS
jomeireh1
Annaba, Algeria
I recently tuned my RS with the Cobb accessport with mountune calibrations and not shortly after threw on a turbosmart BoV. I noticed that the car doesnt feel like its boosting as much. My gauge still goes to around 27 pounds of boost but it doesnt feel like it did before the BoV. I was going to pull the BoV off and tighten it to max settings but I was wondering if I should look into buying a stronger spring psi. Any help snaptube vidmate or recommendations would be appreciated!
