Next performance mod????
Hey guys I’m just curious what you think should be my next performance mod? I have a Cobb AP, AWR RMM, PumaSpeed X47r turbo,3” Whoosh catless DP,3” Thermal R&D exhaust,Whoosh V3 intercooler,Whoosh hot&cold side intercooler piping and a 6 point brace up front .Cold air intake doesn’t do much as the oem one works quite well.
Hey guys I’m just curious what you think should be my next performance mod? I have a Cobb AP, AWR RMM, PumaSpeed X47r turbo, Whoosh V3 intercooler,Whoosh hot&cold side intercooler piping. Cold air intake doesn’t do much as the oem one works quite well.
I vote for Body Aero now....front splitter ...side skirts and rear splitter.
D
I have a S-R low line kit from Delta Styling UK I just need to put on. It’s a front splitter, side skirts and rear spats
D
LSD has my vote. You arguably have enough power already.
Sent from my Pixel 4a using Tapatalk
Yeah that’s kinda what I’ve been thinking but I’m also toying with the idea of adding auxiliary port injection
Next mod....no need to spend the Skrilla!
I would go exhaust. I don’t think our engines sound very nice even with an exhaust but I think the exhaust does improve it. Something low key though but sound is a huge thing for my enjoyment of my car.
flbchbm
I have to agree. I have an LSD. Futhermucking performance, for sure. And like typhoon said, radiator. Mine is waiting to be installed.
D
For got to mention I have a whoosh catless DP and 3”Thermal R&D exhaust
D
Didn't see a Radiator upgrade in there....if that's the case you should be going that route* IMO
Really? my car hardly ever gets over 200 degrees.
Absolutely * mine was the same way. I did it anyways. It's a good protective mod for overheating.
D
What about just getting a 180 degree thermostat?
D
Thread Starter #18
What break setup are you running?
Do you drive in cold sub zero weather? If yes....no don't do a 180°. If you live in an Arid climate it couldn't hurt.
Stock brakes * with the SVT rear bracket Mod and rear SVT rotors. All EBC slotted and yellow pads all the way around. Just Remember you only stop as well as the quality of your tires. I have seen no Reason for a BBK as of yet. I street mine only. NO AUTOCROSS* NO DRAG STRIP* The next major Mod for me is most likely an LSD as I am BT. Then it will all be done with and no more touchy touchy.
