We are building our Fiesta into a streetable time trial car for NASA TT5 competition. We had started with an HS autocross car, then built it for use in the One Lap Of America, now, with the help of MeisterR.com, Team559.com, FSWerks.com, EBC USA Brakes, Stratified, we are getting pretty close to a real competitive car. I am not too media savvy, but will try to keep this thread updated with results, car setup and testing and any other info that seems useful.
The car:
MeisterR GT1 coilovers - Started with 8/6 kg/mm F/R, went to 8/8, and now at 9/10, Jerrick has been a huge help with setup, tuning and advice on the suspension
Team Dynamics Race 1.2 15x8 (sometimes Enkei RPF1 16x7, or SVT Focus 17x7, and considering a re-drill to 4x100 up front to use Konig Dial-in 15x9)
Several different tire sizes and brands tested, latest is 245/40/15 F, 225/45/15 R Toyo RR
FSWerks de-mufflered exhaust
Whoosh Catless DP
Mishimoto Radiator-we still run the track sessions with the heat on high...
Ford 190F Thermostat
Mishimoto Intercooler, custom water cooling sprayers in grill
Mishimoto Catch Can
Currently self tuned stock turbo but have started working with Stratified for the future tunes
11/18/21: Stratified Tune #1 received 11-17, so will use for next event, still stock turbo S280 turbo
Turbosmart Wastegate Actuator 7lb and EM Diverter Valve
Cobb RMM
FSWerks Short Shift Bracket
Quaife diff, plan to go to a wavetrac Gripper soon
12/15/21: Installed Gripper plate diff and fidanza flywheel
K&N Filter in stock intake, cowl intake on order
12/10/21: 2J Cowl Intake installed
Poly torsion beam bushings
poly control arm bushings and +1 caster superpro
Stock Fiesta SE front Sway
Godspeed adjustable endlinks
Custom rear torsion beam brace
Peirce 4 point lower and upper strut braces
Nine Lives Racing rear wing
Versus engineering hood louvers
Stock Brakes with Carbotech/Gloc 12F, 10R pads, working on a custom wilwood front kit with Fastbrakes.com
11/9/21: Installed FastBrakes.com kit. Wilwood 12.2" rotors, Dynalite 4 piston calipers, Gloc R12 pads, fits under TD Race 1.2 15x8 with 10-15mm spacers
5/12/22: EBC 300mm Brake Kit with Anodized instead of powder coated calipers
Whoosh Braided SS Brake Lines
F- 3.5 degrees camber, +1 degree caster, .15 degree toe out, ~315-320mm ride height (Me=iesterR Top Mounts maxed camber and spindle mount bolts maxed for camber to get the 3.5. Had to modify the strut tower to allow for the damping adjustments)
R- Stock camber, .1 degree toe out with custom shims, ~310 mm ride height
Car weighs ~2780lb with me in it and full tank of fuel, corner balanced to 50-50 cross weights, roughly 175whp (probably slightly more when cool out?)
The car:
Whoosh Catless DP
Mishimoto Catch Can
Cobb RMM
![Wink [wink] [wink]](/images/smilies/wink.gif)
