Hi all,
I am new to the forum and indeed to st ownership.
Really could use some advice from you guys that know your field. I got the car with a misfire on cylinders 1 and 4. Oxygen sensor failure on bank 1 and it rattled and banged like a stone in an empty biscuit tin!
The car is a 2017 with 39k on the clock. So far I have cured the misfire by changing the plugs and a new o2 sensor fitted. I have no eml or codes stored, yet the car is hesitant on acceleration/stuttering, but does build boost. On high revs I get some blue smoke from the rear end.
The computer tells me that bank 1 o2 is above voltage limits, running about 1.48v, cylinder 1 seems to have heavy oil contamination on the old and new plugs.
There is no evidence of oil in the plug wells, as in seeping from a rocker gasket. Again what I would say is heavy oil in the intake pipes/pcv pipes (rocker cover to crossover pipe)….. is this normal?
unfortunately I haven’t been able to a compression test as still waiting for the adaptor to my compression tester. I will update when it arrives in a couple of days.
Does anyone have any idea what the issues could be or if I am missing something simple? 🤷♂️
As always, any help is greatly appreciated
Thanks
Dunc
Thanks
Dunc
![Wink [wink] [wink]](/images/smilies/wink.gif)
