Extended lug stud recommendations
I’m going to be installing some spacers. 5mm and 10mm. Where do you all get the extended lug studs from? I see whoosh has some but they are pretty expensive. Any other options or should I just go with the ones whoosh sells?
F
ARP 12mm studs for a late model Camaro are a perfect fit.
Nice. When you say late model are you referring to the most current generation Camaro?
