Sorry if this is in the wrong place, I've searched the forum and haven't found an answer. I'll also say this is my first car made after 1990 if that's not apparent by my question.
My battery died today and after jumping the car to test it at autozone found the battery was completely dead and needed replacement. The negative terminal was so corroded it had practically welded itself to the battery post. Trying to get it off pulled the post off the battery before the terminal came off. Time was an issue so I just bought a generic battery cable (they didn't have an oem battery management module)and ran that from the new battery to ground and left the module plug-in tucked out of the way.
Car started right up, no check engine light, no warnings, nothing. Is it necessary? I found the oem part is $150, and I'm just hesitant after the $250 I just spent on the battery and new connector. I mean, none of my older cars needed it to protect the battery, are newer cars "rougher" on batteries? Can I get by with this for a while? Forever? Or "don't start the car again, replace asap"?
Any help is appreciated, thanks
![Wink [wink] [wink]](/images/smilies/wink.gif)
