Anyone had a BCM issue that causes headlight specifically parking light issues such and randomly turning off or getting no voltage when there should be voltage to the wire? I cannot find any shorts or damaged wires I was told by a tech at my work that it could be my BCM but figured I'd try to get some more insight form you guys.
So, when I check my driver side wiring it has 12 volts to the wire that powers the DRL's or the Parking + wire, and on Passenger Side I am getting 0 volts through the wire but when I plugged the connector in the DRL turned on with no issues.
PS: I currently have DEPO Euro Headlights and running into an issue that causes my DRL to turn off randomly. Seems to fix it when unplug the connector and plug it back in until I turn off the car and turn it back on or mess with the manual switch.
