Diode Dynamics elite series / ss3 amber backlight wiring?
I recently installed the new Elite Series fog lamps from Diode Dynamics that I bought from Whoosh. All is well with those, except that I can't find any information on the splice wiring for the amber backlight feature. There are no instructions from DD apparently, does anyone know how to splice the backlight wires so that I can have that feature linked to my parking lights (or maybe fog-off headlights)? DD just says 'splice to a 12v source using the splicing kit'.
Many thanks!
JDG
Many thanks!
https://www.fiestastforum.com/threads/fiesta-st-head-light-wiring-schematics.2439/
Post #1; green with red is the parking light wire. Use this to power a relay coil, this relay can be wired to the backlighting wire. Alternatively, you can wire the backlight direct to this wire if they pull less than 0.5 A or so.
If you want them to come on whenever the vehicle is on and the fog lights are off. You would need to power a relay with the fog light +12v and wire to the normally closed contacts. Your 12v source would have to be switched with the ignition such that they don’t stay on with the vehicle off.
ethanjds
Thank you, JDG! What exactly would be the purpose of the relay coil for the parking light? You mean to give the option of turning off the backlight? I'm not sure exactly how much power it draws, but I imagine not much.
