Upper Deck Reinforcement shims
none
I have run them and didn't have the cylinders warp. But did have the liners crack, which is also a failure point to these engines.
I am building a brand new block atm and have these shims ready to plug in, just to be sure warping isn't an issue. For the price it can't hurt to use these shims.
Burlington, NC, USA
What are you doing on the new block to prevent liner cracks? Sleeving it?
unspankable
Victoria, BC, Canada
Was there much to install?
Did you have to cool them or heat the block.
Did you need to resurface the block deck after or anything like that.
Thanks for the info
none
Lowering boost and timing to prevent knock and overheating. Was eventually my issue running too much timing and boost for too low an octane fuel.
Did consider getting it sleeved, but might get the old block sleeved if it doesn't last.
Thanks for the info
I didn't install them last time, my mechanic did. And he didn't deck the block and I think he just smacked them in. No heating or cooling. This was years ago and he probably doesn't even remember anymore.
When I get to it, waiting on main/conrod bearings, I'll report back on how they fit. If they fit below the deck.
unspankable
Thanks man appreciate that
none
The shims are loose. The length will keep them in place once the head and headgasket is on.
I'm contemplating giving them a tiny bit of oil/coolant resistant gasket to firm up the fit before fitting the head.
unspankable
Let me know how this all goes and keep me updated please!
Planning to do this soon I'm trying to avoid an Eco boom
unspankable
Dude those shims look hella loose. Is that normal??? I figured there'd be at least an interference fit because they're supposed to push against the liner to reinforce that area.
How would they even work if there's that much clearance????!
none
My thoughts excactly but it's to avoid excessive movement and before they look like this:
Remember the block I will install them into is brand new with no warping. A little warping wouldn't hurt the engine as there is tolereances for this excact reason. Everything moves with heatcycles and wear.
unspankable
When I talked to puma speed they said there are two sizes and recommended I get both because they said my block is probably already a little warped
none
Surprised they mention there's 2 sizes. I should have an old kit lying around somewhere. Will try and find them and see if the new vs old is different in thickness.
Doesn't say on their website.
https://pumaspeed.co.uk/product-Pumaspeed-Fiesta-ST-Block-Mod-Kit_17396.jsp
Pharr, TX, USA
I ordered both sizes and I used the thicker ones. The cylinder that was cracked/warped I used a thinner one and I just banged them in. Added some barsleak copper seal and now I'm up and running again 😎
