Cp-e Rear Motor Mount - Anyone With Experience?
I’m in need of a new RMM. I’ll be getting one of the few that uses rubber bushings instead of polyurethane. So this is basically the Vibra-Technics or the cp-e. I know quite a few people are happy with the vibra, so just wondering if there is any experience with the cp-e for comparison?
Thanks All
I've had both, ('fast road' version of the V-T), and the V-T seems to be a slight bit less NVH prone, especially in the colder temps (which you would rarely have to worry about, unless a trip to the Sierras is in store), before everything in that area of the car warms up.
That being said, I have kept the CP-E instead of selling it like everyone else does, and may be swapping it back on if the V-T starts to wear excessively, or somehow starts getting noisy itself.
Thinking about it now, there was more exhaust system (also a CP-E Nexus in my case) 'buzz' when cold, and in hindsight, it might have been caused by the overly stiff, higher durometer poly Cobb hangers, much more than any non-compliant RMM factor.
Basically, you cannot go wrong with either of these RMMs, but I do believe that the V-T 'road' version might have a slightly lower durometer rubber bushing than the CP-E. [wink]
New_Daily
Thanks. That’s j
Thinking about it now, there was more exhaust system (also a CP-E Nexus in my case) 'bizz' when cold, and in hindsight, it might have been caused by the overly stiff, higher durometer poly Cobb hangers, much more than any non-compliant RMM factor.
Thanks! That’s just the feedback I was looking for.
green_henry
I replaced my Mountune RMM with the cp-e, and it works great -- no complaints.
The (passenger side) cp-e motor mount, on the other hand, increased the NVH significantly. I'm used to it now, but it was pretty jarring at first. No such issue with the RMM for me.
I replaced my Mountune withe VibraTechnis and have not looked. back with a S280 and Tune as well.
New_Daily
Yeah I think that’s what it’s gonna be. Thanks!
My vibratechnics RMM Made alittle over 50k before it needed replacement. I also ran the Trans and Pass. motor mounts too. I'd call it a good life well served in all BT miles. The only grips i had with it is their all one time use* The bushings are poured EPDM rubber i do believe. So this time around i went with AWR Mounts all the way around and for $30 i can get all the bushings in whatever durometer i want for all 3 mounts. [driving] Either way you can't go wrong as anything is a better choice than Stock Poopy*[drummer]
New_Daily
well, I’m coming off a poly bushed unit that lasted 8000 miles before the bushings grenaded. So I’ll take 50k any day. I will not be getting any mounts with poly bushings again. I’m glad I never got around to getting trans or pass motor mounts as I might have gotten poly only to be sad later.
You should get the rest of the mounts* They are worth it.[drinking] I haven't seen anyone complain or talk about AWR Urethane failure alot yet* [ridinghorse]
New_Daily
Something interesting, I think between the fact that I drive the FiST infrequently and that i got the poly bushed RMM so long ago, this new Vibra-Technics caused noticeable vibration and noise compared to the poly RMM that came off with the ruined poly bushes. So, I’m glad I didn’t go with the cpe based on feedback here and from Ron.
But driving, especially shifting hard 1-2, SO much better. Better traction, better on wheel hop, no clunking. Like going aftermarket for the first time all over again.
it will break in a bit and not be noticeable unlesss you have your air on.
Sam4
yep those undercar shots look just like my east coast 125k under carriage...
gtx3076
I have the vibra-tech and I don't think it's any less buzzy than when I first installed it. I am trying a CP-E, and if that doesn't smooth things out I am going to switch back to stock.
I thought the biggest benefit of CPE is rubber bushings that aren’t subject to heat degradation like the polyurethane ones? I have a CPE and Vibratechnics in the garage to replace mountune one when it craps out. Can’t decide which to go with.
New_Daily
Vi
vibra is rubber also. That’s why those 2 specifically were on my list for the replacement
Yes, it is actually distracting just how spotlessly, just rolled off of the assembly line-like sanitary your cars stay underneath in Cali!
Quite 'jelly'.
New_Daily
Thread Starter #18
Quite 'jelly'.
Well yes, the fact I’m in essentially the desert of SoCal has a lot to do with it, but also that it doesn’t get driven daily and never in the rain and every time I’m underneath it I never miss an opportunity to clean stuff.
Brace your eyes, 120k kms in Québec, Canada.
To add a bit to this discussion, I had the COBB RMM for 120k kms and the bushing was ovaled. I replaced it with the Vibra-Technics, and the vibrations were pretty bad. Cold morning buzzing the whole cabin for 3-4 mins bad. I have since ordered all new OEM motor mounts (the two other than the RMM) as I suspect these are gone aswell, exacerbating the vibrations created by the stiffer Vibra RMM. I'll post an update this weekend when I replace them.
