V3 Flash Tune Upgrade Now Available!
Trader history for Jason@dizzytuning (0)
The V3 Fiesta ST Flash Tune is now available! Adding more power, as well as making an even more reliable and cost-effective tuning solution for your 2014-2019 Ford Fiesta ST. You can expect torque gains in the 2,500-5,000 RPM range and even more horsepower carried out to redline!
Since 2017, The Dizzy Tuning Fiesta Flash Tune has been the best bang-for-buck for your Ecoboost powered Fiesta ST. All you need is an AccessPort and $75, and you can transform the performance of your engine into how it should have come from Ford! With the new “Aggressive Pedal” option, power is smooth and predictable, while still packing a punch right under your foot! See for yourself what’s new!
Ford Fiesta ST V3 Flash Tune Upgrade – Dizzy Tuning
Dialcaliper
Jason, to confirm, we can upgrade from your V2 to the new V3 flash tune that has some incremental improvements. Do you happen to have access to a dyno plot overlaying the two?
J
Yes, correct. If you already have my V1 or V2 Flash Tune, then it is a $40 Upgrade fee.
If you do not have my Flash Tune, then any purchase from 12/30/2025 have been getting the new updated version.
I do have a Virtual Dyno graph in the post above, I am working on getting a car on a real dyno.
Would it be possible to have the mods done to the car indicated? Your other post of the Focus ST tunes has this.
J
Recent dyno results from a customer on the new Stage 1 Flash Tune.
Only mods are drop in filter and NGK spark plugs.
J
Your dyno post - the red vs blue on there. I'm assuming that's showing V2 and V3 results?
That's a "Virtual Dyno", which is a tool you can use to uplod street datalogs, and it gives you a very good representation of power from a particualr vehicle.
When used correctly, this can be a great tuning tool for finding power gains and more "area under the curve".
So that graph is showing my v2 Flash Tune vs my v3 Flash Tune.
Same customer, same mods, same stretch of road.
Dialcaliper
Jason nailed it this time, and I’m really impressed.
I was on the fence whether to spend the $40 to upgrade from V2 to V3, but I decided to go ahead. Just flashed on the new V3 (Stage 2) tune yesterday, and wow I’m glad I did.
The first thing I noticed literally immediately on putting the car in gear, pulling out of the driveway and again when shifting into second is that the off-idle and on-off throttle transition has been improved dramatically in the new V3 tune. Pulling away from a stop, coming off the throttle and up/downshifts now feel buttery smooth, even compared to the V2 tune which was already decent. Power delivery feels linear/progressive in a really good way (I opted for the “regular” pedal mapping, not the “aggressive” one)
Of all the flash tunes I’ve tried on the car (Cobb 1-3, Dizzy V2 Stage 1&2 and Stratified Stage 2), this one is the most pleasant to drive in a “smooth is fast” kind of way. Once the roads dry up again I’ll see if I can get some Cobb logs to compare.
What I wanted to highlight is that to me it would have been well worth the $40 upgrade, even if there was no change in the dyno plot from the V2.
J
Thanks so much for the feedback, I'm so glad to hear you are enjoying it!
I second this! Also, may be my car but I see significantly less ignition corrections as well....
What do most people go for regarding the "aggressive pedal" option? I have an aggressive throttle setup on my Stinger but that car is an automatic.
BadShot
I went with no. My car is pretty docile at low RPM/throttle and I drive it around the city a lot so I like the more calm low end.
Dialcaliper
I opted for the standard pedal, and I find it plenty responsive, but also has pedal range to modulate the throttle. I imagine the aggressive pedal to be closer to the way stratified sets their throttle mapping which to me felt too much like an on-off switch (and was especially frustrating in low-boost map). If you rarely drive at part throttle you might like it snappy. To each their own.
I went with yes and am really happy with it. Definitely no more lag but I wouldn't say it's like an on/off switch, still plenty modulation... Stop and go traffic isn't an issue, I also spend a lot of time on dizzys "eco" tune and sit about 30mpg combined
Do you have a dyno comparison between stage 2 v2 and stage 2 v3?
I just tried my 93 octane tune. with the "aggressive pedal" option. To me, it suits the "digital" nature of the car when considering braking with the OEM summer tire pads. It does feel like it runs out of top end quicker but that was to be expected. Might be reason enough to go with the S280? LOL
Cneu
After a day or two on the v3 tune, I like it. I don't have the aggressive pedal or the pop/crackle options.
It might be in my head but shifting seems a bit smoother. Especially from 1st to 2nd.
I got about ~1psi extra out of the turbo but that might just be accidental/good conditions.
I would say that this tune is easier to drive "smooth fast". I can get up to speed just as fast but the shifts just seem to be less bumpy. I agree with dialcaliper.
I'll also mention that I find it easier to ride the traction line with this tune. This might be in my head. What I mean is staying just below that break-loose point seems a bit easier on this tune. I haven't gone to the track yet so I can't say I've really tested this, but it does feel a bit easier to control under power.
My exhaust does "boom" more, but it's easy to avoid if I want to. I say boom because it isn't the crackle or pop, it's more of a bass/low pop than the typical pop. I don't mind it.
Worth the $40.
