Lemon's X47 track ST
lemonjs
United Kingdom
Thread Starter #121
I've begun the next stage in the weight loss. I decided that I'm going to remove the AC and fit a small race heater for de-misting to supplement the heated front screen (which I'm shocked you don't get on the US cars).
I've ordered this AC delete pulley from SiCo Developments, and will soon pick up this heater. I'll run some ducting to the two outer vents and point them to the front windows.
I removed the stock fan assembly today in preparation for all the other stuff. In order to remove this properly, it looks like you'd need to move the cross beam out, so I ended up settling for the destructive method. I then cut out all of the framing that was no longer needed.
Once the AC delete pulley arrives I will remove the radiator, and weld in some plates to block up the holes. At some point this year I will pull the loom and de-pin everything that's no longer needed.
lemonjs
United Kingdom
Thread Starter #122
The AC is fully removed now, and I added a small carbon fibre panel to put switches in. It's not pretty, but good enough for a track car. I still haven't decided what race heater to go for. I've narrowed it down to either a 3.5kw (here) or 5kw (here) unit. Its only job will be to make it bearable in the winter, and to de-mist the door windows.
lemonjs
United Kingdom
Thread Starter #123
Spent some more time removing excess wiring and tidying up the mess I've made over the last few years. My goal is 999kg, which I think will be doable once the rear windows have been replaced with plastic, and potentially a lightweight race battery.
I removed quite a lot this time, fortunately everything that's still in the car works:
Here's what it looked like before:
And after:
And the final weight is 1040kg:
lemonjs
United Kingdom
Thread Starter #124
Plastic windows are in at the rear now too. I really did try and remove the old windows gently, but in the end had to resort to destruction.
Glued in:
And done:
I started with the side windows and make an absolute mess. I'll need to try and find a way of removing the excess adhesive. The rear turned out pretty good once I'd got some practice. I weighed the remains and it came to around 20kg, so I should be around 1020kg total now.
Also, ordered some new driveshafts fgrom Ford which I'll install this week:
lemonjs
United Kingdom
Thread Starter #125
Had a great day out at Castle Combe yesterday. Heard some weird noises after the third session, only to release one of the front tyres was shot. I'm also pretty sure I could hear one of the CV joints clicking, which is crazy given the driveshafts were brand new.
Has anyone heard of brand new driveshafts failing so fast?
lemonjs
United Kingdom
Thread Starter #126
Picked up some Nankang AR1s to replace the front Avon ZZRs, they're pretty square so I hope they have enough clearance. Since swapping back to the road wheels I can no longer hear any weird noises from the front, so I'm praying that it was just the ruined tyres making all the noise.
Next week I'll be going to Snetterton, and will returning to Goodwood in June. I also just booked a trip to the Nurburgring in August and have spoken with Misha about driving the car - crazy excited for that!
I treated the car to a clay bar and polish, the first time I've done this in six years. Forgot it was even orange!
The AR1s are basically THE widest tread width 215/40-17s on the market, at least among the >50 tread wear, any tread at all, DOT donuts. [thumb]
hawyee
Active Duty U.S. Air Force
OKC
What dates in August? We should try to get a bean meetup going
lemonjs
United Kingdom
Thread Starter #130
Travelling on the 22nd, so will be at the Ring all day 23rd and 24th. If you’re there on those days let’s definitely get the beans together!
hawyee
OKC
Not sure the work schedule yet but I'll put it in the calendar!
lemonjs
United Kingdom
Thread Starter #132
Had a fantastic day at Snetterton yesterday. This is a pretty long, technical track with two huge straights.
The car performed incredibly, I can really feel weight loss. Also, going out on brand new Nankang AR1s was a treat!
lemonjs
United Kingdom
Thread Starter #133
To the surprise of no one, it gets quite hot in the car! So now I'm trying to find solutions to problems that I created.
I added a NACA duct to the rear window to duct cool air at me, and initial impressions are that it works fantastically! Going to try and find some bolts with smaller heads as they're a bit chunky.
Back at Castle Combe tomorrow so I'll get to test it on track with a helmet and balaclava.
I've also decided to go for a full cage, so that's on order.
lemonjs
United Kingdom
Thread Starter #134
I was back at Castle Combe this week for a track day. This was a limited day so cost a little more, but there were only around 40 cars total, and no more than 13 out on track at once. The best time of the day was 1:18 which I'm really happy with!
I swapped cars with my friend in the EP3 in one of the pictures below for a session. It's quite amazing the difference in the feel between the two cars. While the EP3 had way more character, and the VTEC actuation made me giggle like a child, the Fiesta is just an all round superior car in my opinion.
For the second time this year at this track, I've ruined a set of tyres. The AR1s lasted two track days before looking like this! I'm going to rotate and try and get another track day out of them, but it's been quite an expensive learning exercise - I'll be going back to the Avon ZZRs next time. I might also try and add another degree of camber to even the wear out a bit more.
Also, the RPX have gone a pinky orange colour. Are they getting too hot? I have brake ducts but I wonder if I need to do something else. The brakes always feel incredible, but I'm slightly concerned with the colour.
Dialcaliper
San Francisco Bay Area
I see the pink on the rotor and in the j-grooves as well. It’s likely just surface rust/oxidation - happens when some pad compounds that are particularly dusty and either have a lot of iron in the pad compound, or are aggressive on the rotors. You can probably wipe or scrape the dust off the pad backing and see the original color underneath.
Mainly it’s a sign that you’re getting the rotors pretty hot.
Fusion Works
Huntsville, AL, USA
Does your cage go through the firewall and connect to the shock towers? Also there is no protection for your feet if you get in a bad front end crash. Could push a tire into the pedal area and break your ankles. Need two bars on each side going forward from the A-pillar down bar to the firewall to protect your feet.
Since you have a cage, you can now start cutting a LOT more material out of the chassis. Get a hole saw and spot weld cutter. Remove the door beams, (and fill the doors with IMPAXX foam), cut out all the material inside the hatch and inner quarters, trim the roof supports or put lots of holes in those parts.
Looks like you are on the right path though and the car looks cool as hell. Yep I am partial to Molten Orange cars. I am going to read through the rest of the thread to see how I can spend more of your money and time. HAHA
lemonjs
United Kingdom
Thread Starter #139
Made a change that I'm sure a bunch of people won't like! I removed the rear valance and drilled some holes in the bumper. I also discovered once it had been removed that it has a rear tow hook! Long term I would like to remove the spare wheel well to make room for a diffuser. MGC sell them over here in the UK.
As Fusion Works said in his comment, I think next steps will be trying to remove some mass from within the car such as the door bars and some of the extra material. The full cage weighs about 20kg more than the one I had before, so would like to make up the difference if I can.
lemonjs
United Kingdom
Thread Starter #140
I was back at Goodwood today. It rained all morning but eventually cleared up and dried out. My quickest lap of the day was a 1:29, which is 5 seconds faster than I managed last time. I'm around 120kg down which must be contributing a lot.
No photographer from today, but I do have a video of the fastest lap:
