Cannot find a solution!! 😐
Indio
NEW:
P0454 (Evaporative Emission (EVAP) System Pressure Sensor/Switch Intermittent.)
History: I was getting the notorious (P1450 unable to bleed code and
very small leak evap code P0456 ) my car was shutting off after fill ups whether i topped it off or not.
ANYWAY, I bought a new 2014 evap harness and my fill up shut off issues went away, BUT the new code P0454 is now showing. I've done alot of research and cannot find a solution!!
Help me, I need to get this damn hoe smogged πŸ˜…
Attached i have added some possible "solutions" but need yalls advice first.
FYI my car is tuned but ive had a previous fiesta with a big turbo and never had any codes.
ron@whoosh
Vendor
Las Vegas
evap purge solenoid or a leak at one of the connections
charcoal canister is cracked or one of the lines connected to it could be leaking / damaged
also replace vapor canister valve
last effort which is rare but I've seen it, is the fuel tank filler neck may need replaced
__diegoortega__
Indio
Is the picture of the (vent tube) a possible culprit too? I think it comes from the vapor canister, it also looks like it has a solenoid on it.
I thought it was a part up front in the bay, but I don't believe so.
Thanks for your help!
Sam4
West Chester, PA, USA
I had a recurring code I thought was the canister - it was a broken wire at the plug. The canister's mounting tab was broken from previous fuck up precision wrenching.
