Cannot find a solution!! 😐
Indio
NEW:
P0454 (Evaporative Emission (EVAP) System Pressure Sensor/Switch Intermittent.)
History: I was getting the notorious (P1450 unable to bleed code and
very small leak evap code P0456 ) my car was shutting off after fill ups whether i topped it off or not.
ANYWAY, I bought a new 2014 evap harness and my fill up shut off issues went away, BUT the new code P0454 is now showing. I've done alot of research and cannot find a solution!!
Help me, I need to get this damn hoe smogged πŸ˜…
Attached i have added some possible "solutions" but need yalls advice first.
FYI my car is tuned but ive had a previous fiesta with a big turbo and never had any codes.
ron@whoosh
Vendor
Las Vegas
evap purge solenoid or a leak at one of the connections
charcoal canister is cracked or one of the lines connected to it could be leaking / damaged
also replace vapor canister valve
last effort which is rare but I've seen it, is the fuel tank filler neck may need replaced
__diegoortega__
Indio
Is the picture of the (vent tube) a possible culprit too? I think it comes from the vapor canister, it also looks like it has a solenoid on it.
I thought it was a part up front in the bay, but I don't believe so.
Thanks for your help!
__diegoortega__
Indio
I had a recurring code I thought was the canister - it was a broken wire at the plug. The canister's mounting tab was broken from previous fuck up precision wrenching.
Okay well it seems I'm definitely gonna have to go towards the back end of the car. The evap harness is brand new and all the connections look good. I'll keep an update.
Montreal
Any update on this, I'm dealing with the same issues. I've replaced every single component of the evap system short of the fuel tank filler neck and it's still stumbling and throwing the two P0456 P1450 codes.
hawyee
Active Duty U.S. Air Force
OKC
The canister is an easy check from under the car one of the nipples on mine was cracked and leaking, replaced it with the rock auto one and no further issues so far.
__diegoortega__
Indio
I replaced my canister, I haven't got a code since
Montreal
I replaced my bank 1 (upper) and bank 2 (lower) oxygen sensors over the weekend and it solved the rough idle and stumbling completely. It runs better than it has in years, I'm really happy.
I also sprayed the capless fuel door with seafoam and worked it back and forth with the gas adapter. I smoked tested the whole intake and evap system and it was working as intended.
The BOSH o2 sensors are cheap on Rockauto, I highly recommend changing them even if they are not throwing codes.
How many miles were on those (original factory??) O2 sensors?
Sam4
West Chester, PA, USA
I know you didn't ask me, but I also had to do a swap out - roughly 25K since install. The bank 2 requires an adapter, it's a woosh v1 catted. But the NTKs dumped and now they're Bosch (too). This was catted and MAP and Clarke install last summer.
Original sensors from 2014, 99k miles (159kms) on oem downpipe.
Here is what the upper (bank 1) one looked like (the one that I had three codes for, P0133, P2195 and P219A)
Thank you! [thumb]
Were they 'cold welded' (or even heat welded, considering their location) into the threaded bungs after that much time, mileage and salt soup exposure, or did they come right out with enough torque?? [dunno]
Montreal
I did previously remove them when doing my subframe this winter, at around 140k kms and they cracked open with an impact wrench. It took an O2 sensor socket with three metal zip ties on it so it would not ''fan out''.
Cleaned up the threads and torqued the new ones to spec. They came new with anti-seize on the threads.
Santa Rosa
replacing the o2 sensor solved the P1450 code?
Montreal
I replaced the purge valve (again) at the same time as doing the O2 sensors. Cleared the codes, and none came back after.
Santa Rosa
Sure. No point in looking back, but I would bet it was the purge lol. Usually an O2 sensor is gonna throw a completely different code.
My OEM DP was cross threaded with the upstream o2 sensor* Luckily i had a High flow Kitty that was going in!
