HELP! Less than 48k & car started 2 stall & fumble while accelerating
fliedlice
Escondido
Even tho my 2016 has less than 48k, I do drive it hard. I'm on 3rd set of brakes & 5th set of tires. Besides the fuel the dealership put in it, I've only put 91 octane or premium gas. 1.5 yrs ago, I started adding octane boost. Besides a cool air induction system, the car is bone stock.
1 week ago driving on freeway, the car started hesitating & I could feel little backfires. There isn't a CEL so I used my obd2 when I got home but it shows no problems. Ive read change coil packs & plugs but could they be bad already with less than 50k miles?Anybody have this at low mileage?
F
fliedlice
Escondido
Thanks 4 responding. There r no codes & no CEL. I didn't pull any spark plugs. I wanted 2 get some responses first. Im disabled so I only want 2 work on it 1 time.
Grsemky
U.S. Navy Veteran
Arizona
I would stop wasting money on octane boosters, they're only adding fractions of a point... Your 91 might be 91.5 with booster which isn't going to do shit
SteveS
Osage Beach, MO, USA
I don't understand your rationale. If you can drive a car with a manual transmission you aren't so disabled that unscrewing a spark plug or four and looking at it would be a big task. When little problems come up on a car, you need to diagnose them. If all you want is a massive parts cannon recommendation, by all means order a new complete engine assembly and swap it [/endsarcasm]. If the plugs are worn or fouled, you're on the way to a diagnosis. There isn't any diagnosis to coil packs really, but they don't usually all four fail at once. I've never had a coil pack fail without a check engine light and a code.
I wasn't going to say anything about the octane booster, but I'll second it being a waste of money if you're already buying premium fuel. What would be a better use for that money would be a bottle of Techron in the last tank of gas before an oil change...that would deal with the next diagnostic step after looking at the plugs.
Sam4
West Chester, PA, USA
Is the stumbling following a fill up? Everything sounds too early ( 5 sets of tires? Wanna be your tirerack rep!), but it could be your evap hose assy - how's the connection to your CAI?
Octane boosters can leave a residue in the cylinders; that eventually build up and contribute to issues.
Running the engine hotter with a fresh set of plugs can help cleanup the cylinders.
