FS DAMAGED OEM Euro Projector (Passengers Side)
Trader history for XanRules (0)
XanRules
Hello!
I figured I'd put this up just in case someone is jonesing for one. If it doesn't sell by the end of the month it's going to the junkyard since it's taking up too much space in my apartment.
This is an OEM Euro LHD Projector Headlight, made by Hella. I bought it off a wrecked car in Germany knowing it had damage to the tabs, but it unfortunately took a nasty bump in shipping that caused the interior plastic housing to break from its mounts - I have tried to show this in the last photo but it's hard to see. As far as I am aware, there is NO way to fix this without opening the light up and I lack the time, oven space, and skill to do that.
I figured if there's someone out there who wants to learn how these lights work and/or learn to retrofit without chopping up a perfectly good set of lights, this is a great donor part, but it is NOT suitable to drive with as the aim is wonky and cannot be corrected.
Electronically, the light works fine - turn signal, high beam, and low beam all operate without issue. Bulbs are not included as they can break during shipping and I don't want to send someone a big jar of broken glass. The lens has minimal damage minus maybe one or two tiny rock/bug chips, but no cracks or leaks. All three tabs are damaged - one has totally broken off, one has broken off and been sloppily repaired, and one is on the way out. These are also repairable. One photo is not uploading correctly for some reason, I've tried multiple times, and may just need to re-take it.
A new one of these is $310 plus international shipping.
I am selling this AS-IS for $80 OR BEST REASONABLE OFFER, plus shipping. This is large and will probably cost between $30 and $50 to ship depending on where you are. If you are local to the Pacific Northwest I'm happy to work out local pickup as I travel between Portland and Seattle often. Also more than happy to provide additional photos or answer any questions. Again, its alternative fate is the junkyard so feel free to make me an offer.
Cheers.
XanRules
XanRules
Thread Starter #2
Still available. Might put it up on CL or eBay, might send it off to the junkyard at the end of the month.
