how are the Coolerworx shifters these days?
ronmcdon
Beverly Hills
I know a couple years ago these weren't the most reliable without additional parts of work. Curious how they work today, as of Aug 2025?
Think I read in these forums they were revised at least once along the way. A few years I almost ordered a unit but decided against one in case they failed at the track or far away. How are they today? Are there any precautionary measures to consider while first installing? Only thing I've found is that it's more of a hassle if one has already installed a Moutune shifter (actually have one sitting in the garage but never installed).
Link to Coolerworx shifter
https://whooshmotorsports.com/products/coolerworx-short-shifter-pro-fiesta-st-2014-2019
With aftermarket shift knobs, anything to avoid like weighted knobs? I know the shift knob uses 12x1.5 thread, so tempted to go with JDC titanium knob at a moderate 10.2 oz. I know the fiesta doesn't go with heavier knobs, but this I am not sure about.
https://jdcustomsusa.com/products/jdc-titanium-piston-type-shift-knob-universal-1
Side note also considered the CAE unit, but seems like a huge hassle having to modify/butcher shifter cables. Whoosh also sells a Hong Kong (one of my favorite places in the world) made WK shifter, but the part seems less proven and on a superficial level, bit too flashy for me.
https://cae-racing.de/CAE-Ultra-Shifter_33
https://whooshmotorsports.com/produ...14-2019-fiesta-st?_pos=1&_sid=51facdc15&_ss=r
rallytaff
Los Angeles
I really enjoyed my 2 year tour in Hong Kong. Fantastic place for food! Worked anti-vice for 6 months arresting street walkers and making sure the girls in the bars and brothels went for their weekly checkups. Had a lot of fun running round Kowloon and had no problems from the Triads!
United Kingdom
I bought one in November 2024 and have had no problems. It’s quite difficult to install as the shifter cables have very little movement and you need to bend them into position.
I went down the route of trying to improve the stock shifter with bushings and short shifters etc, but the Coolerworx is 100x better than you will ever get the stock shifter, it’s probably my favourite mod in the whole car.
Woods247
Atl
I think I might’ve left my shifter base loose when I connect the cables. It was a bit stiff for sure. It was WAY easier than when I installed a CAE kit in a different car that replaces those cables all together though. 😂
ronmcdon
ronmcdon
Beverly Hills
how long did it take you to install?
curious also if it makes it harder to money shift the car, or makes no difference at all. That's one of things i'm mot horrified to do in this car. Had some close calls wanting to shift from 3rd to 4th, almost accidently going into 2nd instead.
Burlington, NC, USA
30 min install, maybe an hour if you’re slow. You’ll want a second set of hands - one to align the shifter and the other to push it into place.
As for money shifting, it may be slightly harder to money shift but I don’t think there’s a massive difference here. The feel is great though and shifts are short. The height is also a huge plus making it easier to reach.
HB, CA
I bought mine in early 2020. It has been on the car since, (knock on wood) no issues. But I also do not track/autocross the car. From the time of install, it would continue to be my daily from then to around 2023 when I started to use it less. During that time, I put about 30k miles. From what I understand, the newer models were redesigned (?) to be a little more reliable since the failures all happened within those first 2 years. I think youre good to go if you wanted one today. I am still using the knob in came with.
United Kingdom
The longest part of the install for me was getting the grub screws set up so it shifted properly into every gear. You should check out the Spark Plug Steve video on how to do this part as it was way more helpful than the documentation that Coolerworx provide.
Woods247
Atl
anything you do to maintain the shifter?
I haven’t touched it since the original installation. As long as it’s setup correctly there shouldn’t be a problem. Getting the set screws correct is critical to prevent overthrow and abnormal stress on hardware.
Fusion Works
Huntsville, AL, USA
I have had mine in the car for about 2 years in November. AS long as you make sure its adjusted correctly and the jamb nuts are tight, I have had no problems. . I love driving it daily.
ronmcdon
ronmcdon
Beverly Hills
some good pointers there with install thanks!
interestingly when purchasing through Whoosh, the part seems to be shipped from abroad, I think Latvia or somewhere in the region with no eta on delivery date, despite tracking info w Fedex.
not a big deal, but something to keep in mind that its maybe not something one can get as quickly as other parts shipped from Whoosh.
ronmcdon
ronmcdon
Beverly Hills
Just got the car back with a bunch of mods and the shifter installed. Really impressed with how easy and pleasure it is to use. Thanks for all the feedback!
I am kicking myself right now for not throwing it on sooner. Just waiting for the titanium shift knob to come in, but so far loving it. Even the shift knob provided is really high quality
