2020 Mk8 Fiesta ST (leaking oil pressure sensor)
Steve D
Hi has anyone else had issues with leaking oil from the oil pressure sensor ?
I had an engine management light come on, so I went to the garage and they plugged it into the diagnostic machine which came up with oil pressure sensor
So they replaced the oil pressure sensor but the engine management light still comes on even after clearing the code
It looks like oil is seeping out from where the wires come out of the oil pressure sensor and it looks like the oil is proceeding up the wire and possibly into the ecu
Anyone else had this problem?
Lee1977
Hi - Yes, unfortunately I have had the same issue. I had the oil pressure sensor replaced, which did not fix the problem. I also had the oil pressure solenoid replaced, which again did not solve the problem. They now seem to think oil has been leaking from the oil pressure sensor and into the ECU. They are saying that it needs to have the wiring loom and ECU replaced. Luckily I have warranty on the vehicle which all parts are covered. However i am not entirely convinced that this will fix the issue. It seems rather extreme to be replacing the ECU and the full wiring loom. The work has not been carried out yet, as they are waiting on the parts to be delivered. So, at the moment I can’t comment on whether this will be solved or not.
Steve D
Hi Lee
Did you fix the issue in the end
Regards Steve
