(Possibly) Blew a head gasket looking for suggestions
#41
Very exciting following this build as I’ve been following SP63 on Facebook and their builds look great for the RS. I hope yours turns out well. Is the price paid for a full turn key long block, or do you have to transfer over accessories and everything else?
arlisscm
Thread Starter #42
I hope it turns out well also (for obvious reasons).
I'll have to transfer over the accessories (alternator, HPFP, Injectors, manifolds, etc.), but I plan to just do a side by side transfer with them both on the bench. (also got all new manifold gaskets, hardware, etc.)
If this all goes well, I'll probably have them give me a quote for rebuilding my stock engine with the same specs/mods to have as a spare. Already have a spare transmission to have Clarke build, so its likely I could end up with a spare built engine and transmission, so I'd probably just get a clutch, pressure plate, flywheel, and slave cylinder slap them together and have a spare unit to just hot swap if/when I need to. But that's all just prospective at this point.
#43
Keep us posted as you have been doing. They’re also only like 6 hours from me so it’s nice to have options within driving distance
#44
One of the very few (if not only?) shops/vendors dealing with our rides which is only about an hour or so from me, but except for the timing belt/water pump/etc. maintenance work, or a factory engine or turbo swap (if ever needed) I most likely will never be able to take advantage of their nuke proof long block expertise. [:(]
arlisscm
Thread Starter #45
Engine is done (or will be done) and shipping out this week. Unfortunately, I'm not able to head down to pick it up, but maybe if/when I have them give my stock engine the same treatment I can make the trip down to drop it off or pick it up.
Between the weather and the garage being occupied at the moment, it will likely be a few weeks before I get stuck into the swap, but I'll be sure to update as I go. View attachment IMG_1579.jpeg
#46
I’ve seen them posting on FB about it and was wondering if it was yours. Very exciting. Did you get any head work done or is it just an OEM head? The block looks beautiful and it looks like the sleeves fully address the slots at the top of the block
arlisscm
Thread Starter #47
Stock head other than having it o-ringed. I haven't seen any of those posts as I don't do social media. :LOL: So you probably have seen more updates/pictures than I have.
arlisscm
Thread Starter #49
Jason has been my guy for a few years now, but because I need good weather (damn you Upstate) to get the miles to break the engine in and the first track day is in May, I'm looking at having it dyno tuned (semi) locally at Circuit Demon, they are ~30 minutes away. It usually takes a few weeks for an e-tune, so I'm likely going to be short on time, so a 1 and done on the dyno seems to be the play.
#50
Did they offer an option to have the crank snout keyed at all?
If so, was that done on this short block?
arlisscm
Thread Starter #51
I believe keyed crank was a $350 option, and yes, I had it done. Figured might as well.
Edit: went back through the email chain, confirmed keyed crank was $350.
arlisscm
Thread Starter #53
Apparently SP63 is right on one of the carriers main routes, so it shipped yesterday and is scheduled to be delivered today. Won't have the space to do anything with it yet other than unwrap it and stare at it for a few weeks. Shipping was $280, I was expecting more, so not too shabby.
arlisscm
Thread Starter #54
Engine was delivered, requested a lift gate truck as the skid steer is currently down so I didn't have anything with forks to grab it off the truck. Turns out the lift gate was broken so the delivery guy and I hoisted the engine and pallet off the truck (with an extra two old guys, not sure if they were holding much or just there for moral support, haha). Suspected a bit of weight as the shipping weight was listed as 380lbs. Well, after unloading it and swapping it from the pallet to a hand cart (and strapping it down) I can confirm these engines are surprisingly light. Our Google overlord says somewhere between 220-250lbs, I'm inclined to believe even slightly less.
Will get some pictures when I get the garage cleaned up a bit.
Looks like one of the VVT solenoid connectors got wacked in transit, it was on the side that was down on the pallet. They are about $60, so no sense in hassling SP63 or the shippers about it, I'll just order a new one.
Edit: had enough points with Ford to cover the solenoid, so I got it for $13 for tax and shipping.
Also wanted to add that the engine came with new intake and exhaust manifold gaskets as well as exhaust manifold studs and nuts. I already got replacements so I guess I'll have spares. Using the studs and nuts I bought as I opted for the ARPs.
