All right so this isn't a fiesta issue however it is in explorer and I figure it's probably the same or similar process. My sister has a 2021 explorer with the push button start. It has one original key and a third party key that I programmed with forscan.
When I first programmed the key it worked fine, unlocked, locked, remote start all that. As this was a spare key it sat in the closet and didn't get used however now that she tried to use it it no longer unlocks locks or remote starts and just flashes three red lights. The key itself will still start the car if it's inside the vehicle. The original factory key works fine both has a remote control and as a key to start the vehicle.
Doe anyone have any ideas on why the key or car would "forget" it's programing for the third party key?
In past Ford's I could program just the remote access function independent of the PATS key chip. Normally I am able to do it with the old series of turning the car to run x number of times in y number of seconds and pushing the buttons however each vehicle generation always had some specific criteria about stuff like doors being open or the car being locked etc.
Thanks in advance
Thanks in advance
