2015 Fiesta ST Winter Beater
ronmcdon
Beverly Hills
oh for both cars, or additional premium for the beater alone?
hard to tell with insurance given it varies so much between location and driving record.
PapaJim13
Kalamazoo, MI
Thread Starter #23
Just for this one. Parents helped me out with insurance on Papa Jim (base fiesta) while in college but I’ll take it over next month.
PapaJim13
Kalamazoo, MI
Thread Starter #24
This is my only accident. Mr Lifted truck with 3 ball hitch jammed er in reverse at my old apartment complex as I drove by.
I mostly fixed the damage and took the insurance payout for like 1200 bucks after cost. Pulled the hinge out with a tie strap, come along, and a hammer till it looked good enough. Can still see I didn’t pull the hinge far enough, but it seals and adds character.
Grsemky
U.S. Navy Veteran
Arizona
View attachment 68085 View attachment 68085
Why does that infotainment screen look odd 🤔 is that aftermarket?
PapaJim13
Kalamazoo, MI
Thread Starter #26
yes! That’s the product of a lot of bullshitting and time. My start of working on cars and wires in general. Night I bought that car the stereo went out. It’s some bullshit with the power cable and I could have fixed it but I didn’t even check it (uneducated moment). Bought one of the only aftermarket screens available and it’s a piece of shit but it works and has Bluetooth and nav). Eventually got pissed I couldn’t turn off traction control in the winter and cut the dash and headliner up to accept the stock controls and screen back in, plus I loved the red lights from the early fiesta models. I’ll take another pic tonight if I remember. Stock controls work and the radio works. Finding what wires to splice was damn impossible. Miles get stuck in kmh but idc.
made that shifter from a brass forging.
do also notice my prized crank windows and my Garfield ornament (G force indicator)
Put in led strips with a jank 12 to 5v usb thing and wired everything to the cigarette lighter so it’s fused and it hasn’t broke or lit on fire yet. All in all, a wonderful learning experience for a complete newbie at the time and I’m proud of it.
Grsemky
U.S. Navy Veteran
Arizona
We all start somewhere, my first foray was spray painting the interior and neon... Thank you early 00's
PapaJim13
Kalamazoo, MI
Thread Starter #28
Had muffler man swap exhausts on my fiestas, putting the stock exhausts back where they belong. Half hour and 400 bucks I’d say not bad at all.
PapaJim13
Kalamazoo, MI
Thread Starter #29
cleaned all the battery connections with Coca Cola and now I have a battery code for low alternator output or something. Also some other codes including the classic vapor emission system bs.
In everyone’s expert opinion, what should I look at first? Battery is from 2023 so I’ll probably start there and I’ll check alternator voltage too.
PapaJim13
Kalamazoo, MI
Thread Starter #30
View attachment IMG_4311.jpeg View attachment IMG_4312.jpeg View attachment IMG_4313.jpeg View attachment IMG_4174.jpeg
Got the new Amazon fog lights as well as another set mounted behind the grille. Yellow rings come on with the headlights, and the bright centers come on with the brights (fused relay power). New oem alternator came destroyed in transit but the replacement replacement works well. First test drive broke the flex pipe so the exhaust shop fixed er back up. Let’s see what breaks next.
PapaJim13
Kalamazoo, MI
Thread Starter #31
First big snow here so I slapped on the winter steelies and slid all around the driveway. Fiancée helped with her crv to pack all the snow down. Still managed to break one of those bumper pieces off in the process.
Did you bend (or were they already bent when you picked up this ride) the stub axles in the back??
WHY does it look like you have 4*+ of POSITIVE camber on the rear wheels??
PapaJim13
Kalamazoo, MI
Thread Starter #33
Haven’t crashed it yet…
I think that’s just the driveway and ice making it look that way. I checked it today and it seems to match the other side.
PapaJim13
Kalamazoo, MI
Thread Starter #34
When I bought the car it was running this 93 tune. I think it a custom tune by (or for?) -McKay M. And was wondering it is reliable/safe. Cars got 213k so I’d assume it’s good. Does anyone know more info on it?
PapaJim13
Kalamazoo, MI
Thread Starter #35
Overheated today and the fan wasn’t on. Checked fuses, all clear there. I’m getting voltage to the fan module and the fan works when directly wired to 12v. Signal wire to the fan module is like 3.4v.
Is the correct diagnosis a bad fan module?
Grsemky
U.S. Navy Veteran
Arizona
#36
Seems likely, do you know the required signal voltage? I'm not sure what it should be🤷🏼‍♂️
PapaJim13
Kalamazoo, MI
Thread Starter #37
YouTube says something bout 12v square waves. I’d imagine my voltmeter is picking up that pwm signal as the 3.4vdc. Lemme check on my ac setting. Wish I had an oscilloscope.
PapaJim13
Kalamazoo, MI
Thread Starter #38
Measures .9vac when the fan should be on. Probably (definitely) measuring incorrectly as the signal probably isn’t 60 hz.
