Rear Axle Bushings and Oversteer
Ireland
My car is knocking at the rear and I'm considering upgrading the OEM axle bushings to Powerflex item (ease of fitment, longevity and lack of needing to tension before tightening up are the main draws over going OEM again).
I love the cars tendency to liftoff oversteer and imagine Ford engineers designed the OEM rubber bushings to influence this behaviour in some way (or maybe not).
Can anyone who's fond of getting a little sideways in their FiST shed any let on whether the cars behaviour in this regard was altered when switching to polyurethane rear axle bushings? I'd really like to hear some feedback before I pull the trigger and order them.
hawyee
Active Duty U.S. Air Force
OKC
Poly bushings make the rear stiffer so it will be easier to induce liftoff oversteer
hawyee
OKC
Yep! Mine has the powerflex black and I almost spun first autocross run with them.
Breandawg
Ireland
Ha, that sounds like fun! Some guy on YouTube said the Powerflex reduced the oversteer which I why I asked, but you've put my mind at ease - time to order!
LilPartyBox
NYC
Pls report back cuz i’m def in the oversteer club! One of my favorite things about the car
Breandawg
Ireland
Well sir, I can report with some confidence that Powerflex rear axle bushings most definitely *will* accentuate the cars natural oversteering tendencies (having just done a 180 on the first roundabout I approached!). Something to get use to, less of a sway and more of a snap from the rear, more delicate throttle and steering inputs required compared to worn OEM bushings (and mine were knackered at 70k miles/10 years old). My rear tyres are pretty worn so fresh rubber would tame things no doubt.
Other first impressions include more positive steering/turn in and of course the dreaded knock resolved.
Despite the utter ballache of fitting (truly terrible, ended up removing the rear axle entirely...in a supermarket carpark...), I would say I'm happy so far!
LilPartyBox
NYC
Sounds like a worthwhile upgrade. Thx for sharing your experience with them. They’re definitely going on my mod list!
