My "new to me" 2015 Fiesta st mk7 have some weird "droning" deep bass frequency in second gear at 1200-2000 rpms when going off throttle. Not sure if is expected. Exhaust is stock
Also, there's a bit of whining noise at high speed when going off throttle, like barely noticeable, that sounds like is coming from the engine bay. Symposer failing?
Once you get used to how rapidly the engine ramps, shift points, plug your symPOSER. Check for exhaust leak. Insure proper fill level and change transmission fluid.
yeah. Coming from a tuned Alfa Mito 1.4 MultiAir 170, i've noticed that the flywheel is heeellla fast at ramping up the revs. Also, the low end torque is insane on that 1.6
