The Official Creak, Rattle and other noise complaint thread
Italy
My "new to me" 2015 Fiesta st mk7 have some weird "droning" deep bass frequency in second gear at 1200-2000 rpms when going off throttle. Not sure if is expected. Exhaust is stock
Italy
Also, there's a bit of whining noise at high speed when going off throttle, like barely noticeable, that sounds like is coming from the engine bay. Symposer failing?
Italy
Once you get used to how rapidly the engine ramps, shift points, plug your symPOSER. Check for exhaust leak. Insure proper fill level and change transmission fluid.
yeah. Coming from a tuned Alfa Mito 1.4 MultiAir 170, i've noticed that the flywheel is heeellla fast at ramping up the revs. Also, the low end torque is insane on that 1.6
Should probably start your own thread so this one isn't filled up with investigatory related posts.
Need more information about the circumstances under which that occurs.
West Chester Pa
Thanks! I did make another post in engine and transmission but not really getting any traffic!
XanRules
Portland
I've seen a few off-and-on here and on different forums about a weird rattling from around the glove box area - in my case, it was the little triangular panel on the very end of the dashboard bumping against the door card. I popped it off, slapped a 4" x 2" piece of 40-duro Sorbothane on it, and put it back. Problem solved.
