(Possibly) Blew a head gasket looking for suggestions
arlisscm
Clyde
Thread Starter #82
So excited for it to start up and run. I hope everything goes smoothly with the break in miles
Right now, looks like I should have it running tomorrow, then barring any major issues, buttoning everything up and driving on Thursday. If all systems are go, driving around aimlessly as much as possible over the weekend.
Suffolk, VA, USA
#84
It’s cool that you have the sandwich plate with the oil temp. It’ll be interesting to see how close or far off the access port is with its calculated oil temp value. Glad it’s up and running and I hope it’s running well!
arlisscm
Clyde
Thread Starter #85
Ran it for 20 minutes or so yesterday to heat it up, bleed the coolant system/oil system, check for leaks and all that. Seemed to be running fine and fired right up without any hesitation.
I'll be starting on the break in miles this afternoon/evening.
From what I was seeing, seems the inferred oil temperature on the AP is ~20 degrees above what I am reading on the gauge in the sandwich plate. Given I have non-stock just about everything, this could be throwing off the assumptions/calculations the ECU uses to interpolate or extrapolate the oil temperature.
Grsemky
U.S. Navy Veteran
Arizona
#86
What did you use to attach the plate? I know it's 3/4-16 thread but I haven't found how long I need the threads into the block
arlisscm
Clyde
Thread Starter #87
I ended up piecing them together separately, but I essentially got this. Just needed to trim the male-male stud ~0.5" shorter (on the external side) to get it to work with the mounting depth on the ST (it's sized for a 1JZ/2JZ).
Grsemky
U.S. Navy Veteran
Arizona
#88
Sweet I was going to use an old SBC coupler but was struggling to confirm both sides had the proper pitch.
arlisscm
Clyde
Thread Starter #89
Yeah, I wasn't 100% sure at first, so I just rolled the dice and can confirm both the block side and filter side are the same 3/4 - 16 thread. So, even a bored out threaded rod or stud could be used if needed.
Grsemky
U.S. Navy Veteran
Arizona
#90
Awesome! Thanks for the info
arlisscm
Clyde
Thread Starter #91
Took it out for a ~20 mile jaunt around the back roads (of Mexico, because my registration and inspection may or may not be current, will be addressing that tomorrow), varying the rpms as much as possible up to 3,500 per the break in instructions. Popped back into the shop after and threw a fresh piece of cardboard under it while I did a visual inspection up top. No marks on the cardboard after 10 minutes.
Everything felt and sounded good, so I would say all systems are go.
Only issue was keeping the revs below 3,500 I wasn't able to get the oil above 180F, so I'm unsure of the extent to which the sandwich plate thermostat opened. Got close, so with a higher ambient at some point during the break in, I should be able to get there. The temp did drop 5-10 degrees quickly a few times, so perhaps that was the thermostat cracking.
Suffolk, VA, USA
#92
Are you running on a base map with the new turbo and motor or did you just load up whatever tune you had finished from the old motor? Just out of curiosity
arlisscm
Clyde
Thread Starter #93
Same finalized map I was running before. Checked with Jason ahead of time and he said as long as the injectors, map sensors and all that are the same it'll be fine.
Even though the engines built, it's still stock cams and stuff, and I transferred over all the sensors and such from my old engine.
Also, during break in I'm not really leaning on it, so timing corrections and boost are minimal.
arlisscm
Clyde
Thread Starter #94
Got through the 1st 150 miles and did the first oil change. Was a little fuzz on the magnetic drain plug, and some shimmer in the pan. A good bit of material in the filter, but it doesn't react to a magnet, so I assume it's aluminum left over from the block machining.
All in all, nothing of note to report. Everything seems happy and healthy, looking like green across the board. More miles slated for tomorrow and perhaps the 2nd oil change if I get extra ambitious and get through the next 150 miles. 1000004000.jpg 1000004003.jpg
arlisscm
Clyde
Thread Starter #96
What are you using for the break-in oil?
Also, what are you going to use once fully broken-in?
Following SP63s requirements:
0-150 miles - Motul 10w-40 break in oil
150-300 miles - conventional 10w-40 (I got castrol, but any decent conventional is fine)
300-500 miles and 500-1000 - conventional again (and again)
1000+ and in perpetuity - Amsoil extended life 100% synthetic 10w-40
arlisscm
Clyde
Thread Starter #97
300 miles done, oil change #2 done.
Basically nothing on the magnetic plug and nothing in the filter this go around.
Small amount of glitter in the pan still.
700 miles and 2 more oil changes to go on the break in. 1000004006.jpg 1000004007.jpg
arlisscm
Clyde
Thread Starter #100
Have you noticed any change in drivability or NVH or anything over a stock motor? I know it hasn’t seen a ton of boost yet
So far everything seems the same/similar. Cruising temperature seemed a little lower today compared to yesterday, even with a higher ambient. Possibly from everything starting to mesh together better. It's also different oil, so who knows.
TLDR just cruising around if I didn't know it was a different engine, I doubt I could tell the difference.
