Troubleshooting Sync 3 Issues
dho510
Bay Area
I've recently purchased a Fiesta ST and the previous owner had no luck getting CarPlay or Android Auto to work.
The car was already on Sync 3 version 3.4.xx when I bought it but would not start up Android Auto when I connected my Pixel 10
I tried troubleshooting with the interrogator log utility as SandMan on cyanlabs forums suggested but after inserting the USB drive and waiting for over 5 minutes, nothing happened and no log was written
also, while driving USB device not recognized error would pop up randomly even with nothing plugged into the USB hub in the center console
and after googling around I see there was an issue with directly upgrading to 3.4 and skipping 2.2. So I set up a USB stick with the 2.2 files and insert it into the USB hub, give it 15 minutes with the car on, but nothing happens, no loading screen pops up, all I get is the Updating System Software message and nothing else
A day later, while driving, a message pops up that says system has updated and I check and it says it is now on version 2.2
I try plugging in my phone and no response. I tried a new USB A to USB C cable. I tried ordering a another HC3Z-19A387-F USB hub from eBay. Neither worked
In fact, when I plug into the new hub, I immediately get the USB device not recognized error again
So at this point I am not sure what next to do. Should I just update it back up to 3.4 and hope that does something even though Android Auto should be working with 2.2?
Is there a bad connection somewhere?
Would replacing the APIM do anything?
Thanks in advance
Richmond, VA
I'm interested in learning more about this too. I just picked up a 2016 FIST and downloaded the lastest version of SYNC directly from Ford on USB. It took 2 days of driving for it to finish the update. It's showing version 3 now. However I can not get my Pixel 8 Pro to bring up Android Auto. To my knowledge we don't have to install a new USB hub for Android to work. I've tried different cables and even the cable that I use daily for Android Auto in my 2020 Ranger and still nothing.
San Diego
What year Fiesta do you have @dho510 If you have a 2014-2015, it could also be the adapter cable that changes the power supply endpoint to fit the new USB Hub power input. Honestly it sounds like your device or the hub isn't getting enough power and is failing to initialize the connection. 3.4 should work for AA/Carplay (granted I've only tested Carplay), if you know someone with an iPhone I'd also have them try initializing carplay. If Carplay works and not AA, then it could be failing APIM. If it doesn't work, your issue likely lies in that wiring path.
If you take off the cowl that covers the APIM and display, there's a USB cable there. Make sure its plugged into the correct slot as there are two available. Also, in the center console on the passenger side there's a USB connection, try reseating that one as well. Lastly, I'd also reset the APIM to defaults.
I have also heard of counterfeit USB Hubs floating around on eBay, hopefully you didn't get a defunct one. Not sure how to test or identify real vs fake though, sorry.
Any reason you haven't used the Syn3updater to go up to 3.4? 2 days to finish an update is a long time, when I did the update on my 2016 back in the day it took about 1 hour from what I remember to upgrade to 2.2.
Richmond, VA
I downloaded the updated SYNC file for my VIN # from Ford.com I didn't know there was another resource. Ford.com had me download version 3.
[/QUOTE]Any reason you haven't used the Syn3updater to go up to 3.4? 2 days to finish an update is a long time, when I did the update on my 2016 back in the day it took about 1 hour from what I remember to upgrade to 2.2.[/QUOTE]
San Diego
I wouldn’t call it a hack, I think it’s the same hardware. Ford doesn’t upgrade all their vehicles because they are “end of life” to use it as an excuse for consumers to buy new vehicles. Plus stuff like maps etc.
SteveS
Osage Beach, MO, USA
It's not really that. The Sync system was designed by Microsoft and was designed to integrate best with Windows phones. I used to use Windows phones, and it worked way better with the phone than AA or Carplay do. But then Microsoft decided to ditch their mobile department and Ford was left with a system that was obsolete. The 3.4 came from other cars which had come new with it, and the people at Cyan Labs adapted it (hacked) to be installable on the Fiesta ST.
Does this mean non-nav version?
If so, you were fortunate just have not bricked the thing.
San Diego
The APIM Hardware had a few iterative changes but the core architecture was the same, which is why 3.4 loads on APIMs that originally could only use 3.0 stock. Ford never installed the "new" APIMs in the Fiesta because they killed off the production lines before the new APIMs made it out. That being said, the CPU was identical.
Cyan Labs found/were told about the "wipe and install" method of updating the head units, which got around the major problem of there not being enough space on the first few generations of APIMs from having the full 3.4 software load and 3.0. (From what I can gather from the software itself it keeps both versions loaded until the new image loads) I do not think the 3.4 software is changed/modified by the Syn3updater as it downloads the software directly from Ford's website. I think the only change is to the loading method, which you can still select the "official" load method.
Also I do want to point out Sync 3 is still in use, for example the 2024 Ford Maverick uses Sync 3 for some of the lower end models. Even if Microsoft isn't supporting the product anymore, Ford is maintaining the codebase.
Richmond, VA
My car has navigation. But I did not update the maps. I have no need for the maps, so I just downloaded 3.0 from Ford.com to update the software and not the second file for the maps. NA mean North America.
I am going to try and update to 3.4 from Cyan Labs this evening and I'll report back if AA works.
jmrtsus
Ooltewah
In 2016 if you bought a non-nav car as I did the Sync 3 could not be updated by Ford due to lack of memory. They replaced my Sync 3 with a newer non-nav version with more memory under warranty. So yes, there are two versions of the software, nav and non nav.
Richmond, VA
Happy to report downloading the latest version of the SYNC update from Cyan Labs worked and Android Auto is fully functional. I do get a warning that the USB hub is not compatible upon start up but once I close the warning it works as it should. Thank you for letting me know about the Cyan Labs work around. If anyone did what I did and downloaded the update from Ford.com first make sure when you download Cyan Labs update that you put the exact version of SYNC that Ford.com provides as the infotainment screen is just going to say "3.0" when the version I downloaded was actually 3.0.23219.
San Diego
That's why I like the Cyanlabs updater so much, because of the "workaround" installation method it makes the install process easier (delete then install versus in-place install). It's like reinstalling windows versus going from Windows 7 -> Windows 10 -> Windows 11, there's always some leftover junk that makes the software work funky.
