It was time to mod my Fiesta pretty soon and what better way than is to change out the suspension? I honestly like the stock suspension set up as is, but I wanted to lower the car without just swapping out the springs. There aren't that many choices for coilovers for the Fiesta ST yet but I narrowed down to 2 coilovers; ST X Coilovers or Bilstein B14 PSS.
They're similarly priced, ST being a bit cheaper from the $100 rebate, but the amount of pro's outweigh the Bilstein, making it the choice
1. Reputation: Bilstein has been making suspension products long before ST with excellent reputation
2. Lifetime warranty: ST suspension has 5 years which seems long enough, but I have heard some horror stories about their RMA process
3. Monotube inverted shocks: Versus twintube design on the ST X coilovers
4. Springs: Bilstein's springs are made by H&R, which are also very reputable company in suspension field. ST makes their own.
5. Corrosion proof: ST is made with galvanized steel versus Triple-C coating on Bilstein
Just picked it up from UPS ship center!
I think most Bilstein coilovers are drop shipped from the manufacturer and I appreciate their thorough packing!
Installation is very simple. I believe RallysportDirect has a DIY on Eibach lowering springs. It's almost the exact same step plus removal of the rear shocks (2-10mm bolts on top, accessable from rear wheel well)
The finished result! The front heights were factory spec and the rear's are about 15 turns down. The rear adjuster comes unassembled so I had to guess how much lower it should be.
The ride quality has definitely improved. The spring rate on the Bilstein's are about 100 lbs higher than the stock so it's not that harsh on my back even on uneven LA freeways. The ride is much less bouncy and highly responsive. With the stock wheels, on a very hard turn, the fronts will scrape. Depending on how heavy you are, result will vary. I weigh about 105 lbs and it does scrape very lightly on a harsh turn or on a bump. I am planning on raising the front just a bit to reduce the scrape and to even the drop with the rear.
Overall, I am very happy with the purchase and highly recommend this to other owners who want nice handling upgrade without breaking the bank. I got this set for about $770 shipped and I bet you can get cheaper one if you shop around. I have not taken over to a track or anything yet, but I will have my test day up at Angeles Crest Highway and I'll update this review.
