Feisty the "Family Car"
Dialcaliper
Good track day at Sonoma, but a bit mixed on the car. Second to last session outside air temp was pushing 90F, the car started overheating at the end of the main straight, scared the crap out of me as the coolant temp shot up immediately and just pegged the meter. It came right back down when I let off and drove easy for half a lap. Brought the car in and didn’t see anything obviously wrong, and the car had handled it just fine previous track days.
Took the car out the last session and the first half of the session was fine, but overheated again in the same place.
Once I got home, I discovered some slimy stuff apparently leaking out of the return for the coolant reservoir (that I’d just replaced late last year when the previous one cracked)
My theory now is that the sort-of leak was preventing the coolant system from pressurizing, and at the end of the main straight after the turbo dumped a bunch of heat into the engine oil, that was causing unpressurized coolant to boil in the sandwich cooler stacked with the oil filter. The sandwich cooler is seemingly in parallel with the rest of the engine, I’m hoping that means the engine is okay and was still getting coolant enough from the bottom of the radiator 🤞
Suspecting another broken/cracked header tank, I ordered a ProAlloy tank from Whoosh. Expensive, but the weld quality of the piece that showed up definitely seems worth the price of entry. Partly I also picked it because it uses an old-school metal radiator cap. I am SO tired of the OEM style plastic radiator caps coming apart!
Dialcaliper
When I went to replace the radiator tank and shift it out of the way it started dripping, so pretty likely it wasn’t sealing.
Once it was apart it became clear that the return nipple had deformed and turned into an oval. The ProAlloy tank was a cinch to install and fits perfectly. Also since it uses a standard cap, picked up a Moroso 24psi radiator cap - slight bump up from the stock cap, but not so much that I’m that worried about raising the pressure, since all the coolant lines have been replaced with high pressure silicone already
Dialcaliper
Trials and tribulations of having chosen 16x8” wheels!
Tried mounting some Conti ECS2 as street tires. Unfortunately while 205/45R16 can theoretically be mounted on 8” rims, it turned what should have been a good street tire into dog**** ride quality. I wasn’t a fan - would probably have endured it, but my wife was NOT HAPPY about the difference in driving feel compared with the 200TW Nankangs.
As everyone knows, street tire options are extremely limited, especially “summer” tires for 16x8” if you want a performance tire that will handle a freeze and give decent treadlife on the street.
Somehow, I happened to stumble across a unicorn tire. Evidently Michelin still produces the PS3 in certain sizes for Audi and Mercedes OE tires they normally sell to dealers. Among the AO and MO stamped tires that are mostly 18”+, there happens to be an oddball 215/45R16 PS3 that was an OE tire for the Audi A1, a car only sold in Europe up through 2018 model year (with this tire equipped)
Never one to pass up an odd challenge, I called up Tire Rack (they’re amazingly helpful over the phone), and they were able to special order them direct from Michelin, which took about 2 weeks (after they had to go through the process of making a new part number in the Tire Rack database system, just for me!)
Lo and behold, on Friday, they showed up at the local tire shop. Not even some sort of backstock, as they carry a 2025 production date and the “AO” Audi Original equipment stamp.
First, the bad. $$$. At $275 a pop, they’re twice the price of other options, and more comparable to the price of the fancy 200TW options in this size.
The good! These are really nice tires. Ride quality and responsiveness are much better than I was hoping for. PS3 may be an old generation tire, but it’s built off similar bones as the newer compound PS4/PS5 Michelin makes. They have a 320 TW rating which means I don’t have to worry about them in the occasional mild winter freeze, and they even carry a 20k mile treadwear warranty. I guess if theyre good enough for OE Audi tires, they should be good enough for my shitbox Fiesta…
Hopefully they’ll last a couple of years on the street now that I’ve got dedicated track tires. With luck they’ll still be making them next time around. Also, Tire Rack now has a part number for them, so it’ll be easier for anyone else that wants to email or call them to order them.
Also, now that I upgraded to the SVT rear brakes, I realized that the 15” compact Fiesta alloy spare I was carrying around in the back no longer fits. The FiST full size spare still works on the back fortunately, but it gave me the excuse to order the correct size spare donut for the 16” SVT alloy spare that’s been sitting in the garage. Off with the 125/85 that won’t fit in the spare tire well, and on with a Subaru size 135/70 that matches the full size spare diameter and fits snugly in the spare tire well.
Now I’ve got a set of Conti ECS2’s sitting around that are almost brand new (only 2000 miles on them) that I’ll probably post for sale. They really belong on a 7” rim.
I wonder if they ever made those PS3s in a 215/40-17 size for when my 200 TW Yok AD09s wear out? [dunno]
Both Michelin and Tire Rack refused to order me in the current Pilot Sport 5 in that size (which is readily available in Europe/the UK), when I asked about them 2 years ago. [thumbdown][:(!]
Dialcaliper
I asked them as well. The PS4 and PS5 simply aren’t being made in this size. Basically it seems like the 215/45R16 PS3 still exists because it is the “AO” stamped Audi original equipment tire for the A1 and the PS3 is still being provided to Audi and Mercedes dealers as a “replacement part”, because like Porsche, Audi and Mercedes are picky about the OE tires they ship with their cars.
The 2025 production date on them was the biggest surprise. I was half expecting 3-4 year old back stock tires to show up
PS3 may be old 2010 tire tech, but they still seem like a pretty good all around summer tire. It’s not like a lot of the closest 205 alternatives (V701, DWS 06, Indy 500 etc) are that much newer in design
My experience is 215/45/16 is not a common size here in Europe either. But that size fits like a glove on those beautiful Königs(yes I have the exact same wheels).
I went with som Advan Fleva V701 in that size(I managed to find them on Autodoc, but the listing is gone now). They are a summer tire for sure. I would not get them out in the freezing cold.
But the tire manufacturers do offer those in Europe at least some UHP all seasons in that size [:(!], whereas we here have none, save for that one 'touring' Vredestein offering that some on here have used.
Dialcaliper
Hah.
I guess since they had to make a part number for my PS3’s, it’s now live on Tire Rack’s website as “special order”, and now comes up in the search results for the size
https://www.tirerack.com/tires/tire...all=Blackwall&partnum=145VR6PS3XLV2&tab=Sizes
Fusion Works
What was wrong with the ECS? No grip? How bad could the ride be compared to the OEM 205/40-17?
Dialcaliper
Maybe we’re getting soft, but the ride quality of the car when recieved (17” Tarmacs with Indy 500) was pretty terrible.
The ECS should have been great in theory. But I think something about the ever so slightly wrong stretch of the 205/45 meant for a 7.5” max on an 8” rim made them unpleasant in all the wrong ways. Compared to the 225/45 CRS (or even the previous 215 RE-71RS) the ECS felt stiffer vertically (hard ride, possibly from requiring higher pressure) and soft laterally (softer sidewalls). I’m blaming the stretch and the short sidewall over the tire brand/model
When your wife tells you the tires ride and drive worse than your track tires, you are incentivized to listen 🤦
The PS3’s definitely feel better as a daily tire on the road. ECS are probably a better hybrid street/track tires. Maybe it’s the slightly taller sidewall, but I’m liking the PS3 on the street and canyon despite their being an “old” tire design. (And higher price point being an OE AO stamped Audi tire which potentially also means deviations from standard PS3 design)
Also worth noting that 205/40 and 205/45 section fall outside what seems to be the “golden rule” of sidewalll height for smaller diameter performance tires. That is optimum sidewall heights in the 95-115mm range.
Fusion Works
The 205/45 is on the low side of that sidewall height. Yeah the 205 definitely does. (I used 90-110, but that is probably in the noise.)
Dialcaliper
It seems like the smaller the rolling diameter, the higher end of that you want to be. Once you get tires over 26-27” rolling diameter you can get away with a little less sidewall height, but not by much. Even the 275/335 meats on a GT3RS have 96-100mm sidewalls
I find it interesting that actual radial race tires tend to have even taller sidewalls. The Porsche GT3 cup cars run 18” slicks, again with nominal 96mm F and 126mm R sidewall heights. Hell, F1 only grudgingly went to silly 18” wheels with a mere 131mm sidewall, from the old 13” balloon tires that were even taller
My idle pondering leads me to believe the sweet spot in sidewall height and vertical stiffness are directly related to coupling in series with the 2.0-2.5Hz suspension frequencies that also maximize mechanical tire grip. Make the combined frequency too high with too stiff a tire, and it’s just like running overly stiff springs.
You didn't want to try the new BFGoodrich g-Force Rival + ? They come in 215/45R16.
I was really tempted, but the universal problem with all 200TW tires, even the endurance ones is that they are not safe for even the occasional freeze, and the BFGs especially are sketchy in the rain.
Since I have dedicated track wheels now, it makes more sense to have a true street tire. The PS3’s are expensive but similarly priced to the 200TW offerings, and check all the street tire boxes including the ones the Rival + and similar don’t. (Like a 20k mile treadwear warranty!)
Since getting more opportunities to track the car, I’ve also cooled my heels a bit on the street. 😂
