Mystery "boost leak" - where to go from here?
2019 Fiesta ST, 81k miles, running the Stratified flash tune for the past 6 years/75k miles. Drop-in filter, symposer delete, and Whoosh catted DP were the only mods at the beginning of this saga.
I dusted off the old Accessport recently to monitor coolant temps, and noticed I was only seeing around 22 PSIG peak boost. I don't recall how it ran 6 years ago, but I was expecting more like 25 PSIG. WGDC was pegged out at ~85% the entire time. Threw the data log in vdyno and it came back with 174hp, which also seems low. Here's the log:
https://datazap.me/u/banana_z06/log...els=7x4&sizes=50x50&sc=3-4-6-7-23&axes=shared
Installed the Whoosh v3 FMIC I've had laying in the garage for the past 6 years. Made no difference other than losing 0.5 PSI or so of boost (as expected).
Installed a GFB DV+ last weekend, tightened every single hose clamp (other than one right before the throttle body I couldn't reach), and installed a new air filter. Made zero notable difference. Still seeing ~22 PSIG peak boost with WGDC flatlined at 85% the entire time.
Flashed the Cobb stage 2 OTS tune -16 PSIG peak at 65% WGDC (tune seems to be limited to 65%?).
Is there anything obvious I could be missing before I try to cobble together a boost leak test setup and find someone with an air compressor to borrow? Car runs fine, no codes, gets the same gas mileage it always has. Most of the posts I've found about boost issues have people getting CELs and being stuck at wastegate pressure, which is not the case here.
Possibly a failing boost control solenoid? Maybe it's not fully closed and is venting more than what the duty cycle is telling it to/expecting? I had one fail but it failed closed so my boost spiked to ~32psi which was spooky on 93 octane, luckily it didn't hurt anything.
My fiesta is currently in the garage half-disassembled with a very similar problem, I'm building out a new turbo because in my case at least it appears to be a turbo seal failure.
If you have any parts stores nearby, I'd recommend seeing if they can rent out a smoke test machine or boost test kit. None of the shops near me had one, so I ended up buying a boost tester kit off amazon.
On a separate note, hello fellow Corvette/Fiesta owner!
Grsemky
I'll upload my most recent data log when I get home, but on a dizzy stage 2 91 tune , my VDyno showed 176whp and 232wtrq here in the desert with 100⁰ ambient. So yours might not be far off, my max boost was just under 24psi
